Stop in for a cup of coffee
It was too big for the smaller A bodies. The 61's and 62's only came with /6's. 63's were redesigned but the poly still wouldn't fit. Poof, the 273 La was born.
That Poly would have been a great truck engine, and no problem fitting it.
When I was working on my baby Dodge today I looked at the headlights, and now it is overcast it is better to see inside. It looks like it is a H4 or H7 light bulb inside, I mean with that typical black cap on with the little tip. So, I guess that mean it is a halogen light. But, it is still fairly yellow light, so I guess I have to look at the voltage that comes to the lamp.
Bill
In decent light look at the lens. The codes will tell you what they are. There are fakes - sometimes they can be figured from the codes not making sense. LOL.
US market lamps will have HR for Halogen Replaceable. They are designed for the HB2 bulb, almost the same as H4.
ECE market lamps will have HCR and take H4 bulb.
The higher the voltage they get, the more current they will draw. On battery power they're getting 12.8 V at best.
If you go to that Candlepower thread with the H4 bulb comparison, you can see the difference higher voltages make in current and light output.
You said the higher the voltage the higher the current? Hmm, Ohms law says otherwise...
That's how I used to think about it too. You know, like going to a 220 V AC motor from a 110.
The voltage in this case is the supply voltage.
P= IV and V=IR
Nominal 60 Watt lamp at 12 Volts draws 5 amps,
and so at 14 volts it should only draw 4.3 amps.
But that's wrong. :(
With a lamp and many other devices, resistance stays roughly the same, not the power.
Lets say that nominal 60 Watt lamp was rated at 12 Volts.
12 volts = 5 amps x R, R = 2.4 Ohms
then
14 volts = I x 2.4 Ohms, I = 5.8 amps
solving for the new power at 14 Volts
P= 14 volts x 5.8 amps
P = 81 Watts.
All assuming I didn't make a mistake.
P= IV and V=IR
then
P = 81 Watts.
Hmmmm
P= IV and V=IR
then
P = 81 Watts.
Hmmmm, OK. Never thought of this with bulbs...:thankyou:
Here's the post about the H4 bulb tests.
Interesting headlight bulb test results
He tested at 13.5 Volts and then converts to some of the other common reference voltages.
He mentions that
US standard is for wattage to be stated at 12.8 Volts.
UN/ECE standard for wattage for same type of bulb is at 13.2 Volts.
So based on that, we clearly can't compare 'wattage' of an 9003 or HB2/H4 given in US Standard to an H4 in ECE standard without doing some math.
Fun 'eh?
Got the following from Stern's website:
Headlamp bulb light output is severely compromised with decreased voltage. The drop in light output is not linear, it is exponential with the power 3.4. For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages:
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
12.8V : 1000 lumens ←Rated output voltage
13.0V : 1054 lumens
13.5V : 1198 lumens
14.0V : 1356 lumens ←Rated life voltage
14.5V : 1528 lumens
from here: Daniel Stern Lighting Consultancy and Supply
Now the other question is.
who's still awake?
Speaking of class.
Did anyone else hear the newly released live tape of Tom Lehrer at a show?
It includes another version of his song of all the elements in the periodic table.
It's a classic version.
One Aristotle would recognize.
All four elements.
:lol:
I thought about it 'cause I was confused about it for a long while. Now I can explain it and my head doesn't hurt.
So you are saying because a bulbs resistance stays the same no matter the voltage?
I have been on cruises, just not like this....Mexican cruises...
I thought it was very amusing, the little shorty 3 day cruise from San Pedro to Ensenada and back. It was the New Years Day edition. All the Mai Tais you could drink at the Captain's cocktail party, so I did. First night was pretty much straight to Ensenada and dock. I wake up the next morning, take a short walk to the upper deck, there was a heavily armed Federale Soldier staring at me from a gun tower on the dock :eek:. Surprise! :lol:
Yes.
I suppose the heat must change the resistance somewhat, but not enough to worry about.
With enough voltage from a good power supply on it, it will draw enough current to burn out.
That makes sense?
or did you mean?
:poke:
Yes.
That makes sense?
Yes....
P= IV and V=IR
then
P = 81 Watts.
I always though about light and voltage this way...
Higher voltage means more electrons per unit time that can be converted to photons.
Amps determine how fast the supply of electrons can be replenished (or sustained at steady draw rate) to maintain the photon emission rate (luminosity).
In other words, higher voltage means more photons (light output) as long as it is not restricted by resistance to amperage flow that chokes off the electrons being converted to photons.
