Ddaddy
Just doing what I do
Here it is running...
Should have bought sonething red!So I tested the brand new condenser from John Deere using every means I could find on google, no resistance at all with a multimeter. Nor does the spare I bought today either. So I’m either testing it wrong or they’re both bad.
Everything else checks out fine. Cool, plug wires, new plugs. The leads from the dizzy to coil. Bypassed the switch. Yet no spark. Point is gapped to .022 as per the fsm. Rotor spins and is in time per the marks.
This on an old model 60 John Deere. Entire ignition system has been swapped out and still no spark. It’s a positive ground system as well. No ballast. Anyone got any theories?
You might as well be speaking mandarin. It will make about as much sense to him.When you apply a resistance check on a capacitor, the needle should swing over. Analog meter with a power source like AA or 9V battery.
Otherwise you need a meter that does capacitance.
Typically its power source to coil - in your case maybe coil negative if was for a positve ground application, then to the points. When the points close, current should flow through the coil primary windings to ground.
There is one other thing about AM - the magic. Especially when driving at night on the interstates with the windows up, pull the antenna up and just move down the dial and see what gets picked up. Kindof fun to pick up stations many states away or in canada.I don’t really listen to the radio in my cars much, even in the newer ones that have satellite radio. I only turn them on about 5% of the time I’m behind the wheel and generally only when I am stuck in bumper-to-bumper traffic. Otherwise, I would rather listen to the engine and the road.
I have only turned the aftermarket underdash AM/FM/CD stereo on in the GTS once since I have owned it. I am going to pull it out and just have the AM Music Master for now. If I get ambitious, I will swap it for one of the new vintage case am/fm units that look just like the original but have modern electronics in them. At least that way I could power the rear deck speakers.
Testing condensers without a dedicated tester is impossible. Analog multi-meter on ohms scale test one way, then reverse leads. Needle will bump if its not open or shorted.
Depending on meter, battery size matters. 9 volt powered ones are better.
Or just holding on to wire,tag it across 12 volts then hand it to your wife. If she gets a snap then its good...
It’s a 9 volt analog. Not even getting spark at all. I’m getting 12 volts to the positive side of the coil. Not getting a thing at the condenser. Thinking about taking it out and sending it to hoppy.And not knowing the microfarads needed for your particular application, testing is pointless.
An engine will run without a condenser, just not very well. value is important, as it prolongs the life of the contact set.
fixedOr just holding on to wire,tag it across 12 volts then hand it to your wife. If she jumps back and then knees you in the nuts, then its good...
RIP andDamn, my wife's uncle just passed away. And my youngest son announced he is turning into a woman. WTF is happening here?
Sorry for your loss. On both.Damn, my wife's uncle just passed away. And my youngest son announced he is turning into a woman. WTF is happening here?
Jeez! Sounds like an episode of the Twilight zone.Damn, my wife's uncle just passed away. And my youngest son announced he is turning into a woman. WTF is happening here?
If it's positive ground, shouldn't you be getting 12 volts to the negative side?It’s a 9 volt analog. Not even getting spark at all. I’m getting 12 volts to the positive side of the coil. Not getting a thing at the condenser. Thinking about taking it out and sending it to hoppy.
You need to clean and adjust the points.pos to coil,neg to points,points ground. I test coil neg to ground with an ohmmeter, with points on low side of lobe,points lead should be grounded.It’s a 9 volt analog. Not even getting spark at all. I’m getting 12 volts to the positive side of the coil. Not getting a thing at the condenser. Thinking about taking it out and sending it to hoppy.
frank's more of a help here than I am.It’s a 9 volt analog. Not even getting spark at all. I’m getting 12 volts to the positive side of the coil. Not getting a thing at the condenser. Thinking about taking it out and sending it to hoppy.
Holy fark! That's a bad bout of news.. Not sure there are any words.Damn, my wife's uncle just passed away. And my youngest son announced he is turning into a woman. WTF is happening here?
My condolances. On both counts. your son is still your child,regardless what path he chooses.Damn, my wife's uncle just passed away. And my youngest son announced he is turning into a woman. WTF is happening here?
I miss something? Positive ground?frank's more of a help here than I am.
Not that it should matter much but lets see if you can explain what you've got here. yes no is fine
This is a 12 Volt battery powered system.
Battery positive is connected to the engine block or head.
Battery negative goes through an on/off switch to the coil negative.
Flip the power on (or connect the wire) and the coil positive shows 12 Volts.
Coil positive leads to the points.
Yep. You and Chris both!I miss something? Positive ground?
@halifaxhops or anyone else, any way to check a condenser in a points dizzy to see if it’s good?
Interesting... Never had a trailer. So, while I knew they made different tires for trailers, I never gave much thought to why. There are reasons not to swap either way. Just did a little quick google read... While most people know the trailer tire is not speed rated for a car (but seam to forget that when pulling a trailer) They also don't have as good of tread for both wear and traction. Going the other direction- car tires don't have the heavy sidewall that trailer tires do. This is to reduce sway.
