dukeboy440
So I may have missed it and probably did, is Tim otw back to CA with the dart yet?
My dad has a 48 model B.Let me know if you all can see that video
That sucksWell batting 0 for 3 today. Mains on the truck are too tight, (.001 instead of .0025).
So motors coming back out and get to tear it back down to polish the crank again.
Found hairline crack in oil pan for the truck.
Got everything back together on the 63, oil, filter, exhaust, plugs. Adding coolant and the new head gasket is trash. Its torqued to spec but there goes the new oil and coolant.
I guess he took the fastest route, which didn't include going through CO.@dukeboy_318 Tim left Texas @ 01:30 PDT I think he said. He should be in Ca by now.
His last post was at 3:11 am Pacific time. He had left Texas about 2 hours earlier and was stopping for some sleep. Will probably be a just while longer before he is home.@dukeboy_318 Tim left Texas @ 01:30 PDT I think he said. He should be in Ca by now.
The first pic was rug cleaner...Says on the label that it has zinc.
I don't know how much is 'enough'. But I would guess with the way they promote it, should be more than enough for a driver. Don't know about a race motor...But does it have enough, that was what I guess I was after.
Bill
Race engine? Depends on the engine. Roller cam or flat tappers?I don't know how much is 'enough'. But I would guess with the way they promote it, should be more than enough for a driver. Don't know about a race motor...
The ZDDP requirements are very different for each. Too much in one may be not enough in another...and vice-versa.
For that engine, your choice is fine. It only needs a bit of ZDDP to make it happy and keep it running strong. It is a flat tappet engine, but not a high RPM race motor. The amount of ZDDP in that oil is plenty good enough.1965 225 stock Slant Six, most likely unopened, said to be around 90000 miles or in that neighborhood.
Bill
My Dad was a Ph.D chemist for Sunoco for over 30 years. Our family’s 1966 327 cid Impala station wagon was one of the test mules for unleaded fuels back in the 70s. It was also a test mule for different oils types, additives and blends. Sunoco rebuilt the engine completely when the testing was done.Oil brands is sort of a can of worms, there is a lot of opinions about them. Could still be fun to hear if someone has had bad experience or very good experience with that oil.
Bill
When I was truck pulling and working for the team, we tried everything one could think of to squeeze power. Including oils.Oil brands is sort of a can of worms, there is a lot of opinions about them. Could still be fun to hear if someone has had bad experience or very good experience with that oil. Or if someone else is using Kendall oils.
Bill
You are referring to BlackStone Labs and the information you get is only as good as your ability to interpret what it means. For most average drivers, it is a waste of time and money to do oil analysis. Most don’t understand what the results mean or how to put them into contex for their application.When I was truck pulling and working for the team, we tried everything one could think of to squeeze power. Including oils.
The best advice, forget the advertising, send off your oil to a company that does oil sample testing. They can tell you the microscopic parts of metal that are in your oil and how well it’s protecting and lasting.
The filter brand is highly important as well, if you’re running a fram or Walmart type special, forget the oil supplements, upgrade the filters, then the oils.
Oil sampling is cheap and you might be surprised at the results.
That doesn’t look goodView attachment 1715409045
Tank battery Contra Costa County Ca. 2 tanks that were allegedly less than 1% filled with ethanol. I80 on one side Phillips refinery on the other.
