goldfish65
Ok gonna go hunt for old Mad Magazines and report back later! Thanks!
Check out the philosophy books I think it is a penguin or a platypus walk into a bar. They are hilarious.Any suggestions for funny books I can send my buddy who is laid up a while? He is an engineer. Probably extra hard for him to just lie around. Me Talk Pretty One Day by David Sedaris is a good one if you want to laugh.
Yep, French PressIt was very good.
Helped by the fact it was fresh ground and maybe how you made it. Was that pressed?
Looking forward to trying it.
Noted thanks! I’m think of a 40x4042x48x16, not big enough either!
THey have them at Wal Mart. I used to eat them until my heart surgery and found out the sodium in my diet was killing me. LOLYou can buy them?
Didn't know that. Thought you had to get 'em fresh.
My relatives used to drive up to Alabama or close to it and buy 'em green from roadside stands. Then bring 'em back and boil 'em. Pretty good.
(That's not a long drive when you live outside of Pensacola.)
My wife has the directions written down and taped to the cupboard door. "one measure for 4 cups" LOLMorning.
Wife is making coffee. Freakin disaster. Can read directions but sure as hell dont understand em.
Great Idea! Borrow one of your peoples crayons to do that? That's why they let you be a boss...I fixed my clock for the time change.
Would LA headers work?The only different between a poly and an LA is only with anything to do with the heads and valve train system. Everything block related is the same as an LA with the exception being the pistons mainly due to valve locations.
no. Port spacings are completely different. However, Ford GT 5.0 headers WILL work with a slight flange modification. I couldn't make them fit in the B body but the truck engine bay is much wider so they may clear.Would LA headers work?
that'd be me. You can modifiy the bolt holes and use small block ford headers, Mustang 5.0 GT headers work best for that.Somebody mentioned something about Poly headers the other day. SBF? One of the evenly spaced exhaust variety heads. Just needed some massaging on the bolt holes of the headers.
