Unconventional
Sounds like the rain let up. Beer/supply run time.
The tree trimmer was here from the power company... Cut up some of the wood, but did not clear all of the lines... Now they have to send him back to finish the job....
And this is what they call the "widow maker"... I picked up one of those long pole tree trimmers to take this down when we get a day of no rain...
So am I , sort of......
Can't speak to newer houses but older houses rarely had any insulation. If not - first place it was added was the attic floor, then walls.
With central heat and hot water - the furnace and heater was usually in the basement. The heat from the furnace warms the floor so really no reason to insulate.
Over the coal bin - that's where I'll sometimes see the cieling above covered.
Dashboard on the older cars was usually darker with a matte or suede finish. I think your car looks sharp in its original colors - and a light color is cooler in the sun.
That's a lot of wood!The tree trimmer was here from the power company... Cut up some of the wood, but did not clear all of the lines... Now they have to send him back to finish the job....
How high up is that? Did you get a power saw or hand saw? My pole saw is 10" bar. Can't tell how big that is in the pic, but I'm guessing over a food. As much as I hate paying for work tree work, I think I would hire a pro to drop that on the ground if you cant get the power co to do it for you.And this is what they call the "widow maker"... I picked up one of those long pole tree trimmers to take this down when we get a day of no rain...
Your supposed to do that before it startsSounds like the rain let up. Beer/supply run time.
Bourbon is for sipping. Take shots of the Canadian stuff.When you need a shot of Bourbon and you’re out!
Rolex, Timex, Seiko...Howdy all. 3 watches to go!
I have been looking around at that stich welding system, seriously cool just not chea to get the right stuff. I am really on the fence on fixing it that way or use PC-7 on that hairline crack on the slant. Same area as this on but not as bad prob half of it. I know not a slant.
Precision Metal Stitching Repair - Turlock, CA - LOCK-N-STITCH Inc.
Actually I used to sell Rolex's.Your supposed to do that before it starts
5LB of that rod is about 250.00! Not cheap!! BUT it sure works good....When I worked at a boat yard in my younger years a salesman came in and presented a new welding rod none of us had heard about. It was called Certanium. The salesman was a former welder, and a good one. But, my boss was sceptical and wanted him to prove what he claimed. He said one of their rods could weld directly on any cast iron or cast steel, he could even weld cylinder sleeves. He said the electrode was fine for repairing cylinder blocks, and if a cylinder block had a mounting for a generator for example, and it broke off, he could fabricate a piece out of regular steel bar and weld it on to the block, and it would be fine. We thought he was just pulling our leg. The guy then claimed that if a cylinder block was cracked in the side, and it was leaking coolant, he would use the angle grinder to grind in a bit, like a V, and then just weld, and it would close it, and it would not continue to crack. My boss was just shaking his head.
The guy wanted to prove what he had said, and was taken to the workshop, and one of the guys gave him an old and worn out cylinder sleeve we had just replaced on a 6 cylinder Volvo Penta marine engine. The guy said, I am going to crack it in 4 quarters, and weld it back together again, and you can then put it in the vise and squeeze it until it cracks again. And I can guarantee you it will not crack near the welds. So, the guy did as he had said, and the guy who had found the sleeve put it in the vise, and tightened it. The sleeve cracked again, about mid between the welds. The guy who had picked out the sleeve was also our best welder, so he said, can you weld forged steel to cast iron the way you said ? He got a worn out cast iron pulley and a 4 inch long flat steel bar of forged steel. He welded it, and the vise was massive and they smacked the flat iron bar with a sledge so the pulley flew out of the vise. The iron bar was still on the pulley. They put it back several times and tightened it, and smacked the flat iron with the sledge from several angles, but it did not come loose. My boss and all the others including myself could not believe our eyes. We bought some rods, and some months later a fishing boat came in with a cracked block, and the best welder went onboard, prepared the crack as the other guy said, and welded it. We never heard from the guy again about the crack, and he used to come in to us for maintenance jobs from time to time but the engine was fine.
Bill
I believe that is correct. Have cut up more than a few of them and that's what it looks like.Is that red oak?
So I was doing some research. From a bearing standpoint alone, the KH spindle for the outer has a .750 vs the Ford which is nearly .14 bigger in diameter. I’m sure you could find a bearing that might work, though.5LB of that rod is about 250.00! Not cheap!! BUT it sure works good....
Had a front leaf spring hanger, cast iron, on a international semi tractor, cracked in a major crash. I welded it back together with that rod, never had a issue with it.You can repair a lot of cracks with 5 lbs of welding rods. And all you save on other stuff, not having to heat up the block, or whatever else.
Bill
Any fires still going on down in south ?
Bill
Hi mr. Bill, are you having a great evening,??I know, it is kind of sad, because when you tell about it people will not believe it. I worked with the boats in the 1980ties, so it was already around then. And people are like, it can not be this good, it must be a catch, we better do it the old way, and ended up with a far more expensive repair because of disassembling, machining and all kind of things they had to do. The repairs were high quality, with all that job done, no doubt about that, so it was like, doing it this simple, it can't be a good job.
Bill
I never wear watches..... the wristband is usually too big and watch face goes all the way around my wrist so I end up hitting it on things.Howdy all. 3 watches to go!
