Stop in for a cup of coffee
I disagree a tiny bit. I think the Nats vendor area and race area are larger. Part of that feeling though may be that the Nats are much more spread out.
Now I do think the swap meet area at Carlisle is probably 5-10 times bigger than the Nats. And that’s a conservative guess. I did like Carlisle better than the Nats because of the swap meet oh and meeting you all.
Speaking of Carlisle, my unit is being really wishy washy about me doing an Alternative Training for those days. One minute, it’s yes, we’ll get Battalion to ok it, next, not so much. So I’m probably just gonna miss out this year.
But I know there’s a couple shows west of me that I may try and hit. Craig, when’s that one near you?
MITP is a three day show weekend after Memorial Day.
MOPAR show in Omaha is a one day Saturday show mid May.
Chris you should see the size of Hershey. HUGE. A mix of everything you can imagine. Takes easily three days to properly see it all. and three truck loads for Tim! I am guilty also found a few super deals also.
Need to make it to Omaha one of these years. A 4 hour drive for me but so is MITP. A bunch more for you and Cheryl.
Sounds small, but with self adhesive much bigger would probably be a PITA
I ran the vac over the floorboards and wiped the down with a wet towel.
Easy on, hit it with a small carpet roller and done.
I've had the rear seats out a couple times since and it hasn't moved or peeled.
Chris you should see the size of Hershey. HUGE. A mix of everything you can imagine. Takes easily three days to properly see it all. and tree truck loads for Tim!
I was hoping to get there for the actual car show this year. But I think it rained Saturday and I had to work. Would like to show the Duster there one year. I think they have a lot more original cars. Definitely more of the focus since it is an Antique Club event
I wonder how bedliner would work on something stripped like the cuda?
Not very well if it’s smooth, it’ll need to be scratched up and rough . Been there, done that, flakes up over time. Even a 1/4 in thick stuff
A lot of guys are spraying bedliner under chassis for drivers. It's new styled undercoating. It probably makes things quieter and less heat.
I used that bulldog brand on the truck bed just hit it with a pressure washer and sanding sponges holding up great so far beat the hell out of it also.
Nebraska is one of the few states I need to check off my list. Depending on the dates, that may work.
MITP, mopars in the park? That might work as well date wise.
what’s in Hershey?
I found it really depends on the prep work. As with any coatings.
Put on by the Antique Automobile Club of America. Lots of early stuff, signs, pumps, bikes @Mopar Tim you name it. all makes. Really cool just to walk around and look.
Nice!! Putting that on the google search list.
looks like both MITP and The one in Omaha are the exact same distance and time from me. Bad part is, I have to drive thru Illinois no matter what to get to either of them :(
Usually in the dash with a cable. I actually have a box of new 5" tachs for them. Have seen column mounted also.
Now cables are a PIA to find in the right length, no universals that I have found yet that you can cut down.
Taking the dive out of the distribs sucks really easy to mess it up. Two pieces press fit together
