Maybe when I come thru there in July, I could look at it?no, not busted, but they did screw up, promoted me, then realized they didn’t have the slot and after a year, demoted me as a “re org” and then randomly slotted next in that ranks slot but in a MOS I didn’t have, which left me stuck for years. And sad part, I caught them trying to do the same just last week.
mechanic? Hell I need an electrician
My dad used to say of pretty women, "Body by Fisher, Brain by Disney"Body by Fisher was GM Fisher Body - Wikipedia
OMG Chris, Electricity does not care what color the insulation is!!!!!!So looking at this, it doesn’t really confirm to me, that this Polara is infact a negative ground. I’m so confused because all the Polaras in the junkyard all had black cables going to the starter, red ones to the block. Even pulled the original harness out of the box and it was the same
wow, looking threw this book it's mostly all gm products, wiring to putting stripes on the body correctly
Better get some Red paint on it soon, or it will short out........
But your local code inspector will!OMG Chris, Electricity does not care what color the insulation is!!!!!!
What happens if they are black and blue?????Better get some Red paint on it soon, or it will short out........
Does a red cap fix it so it runs right?
They're bruised!What happens if they are black and blue?????
No f'n way!I used to be responsible..
all of them? With factory insulation?Im sure it is negative ground. The fact that some you saw had black cables to the starter , implies that someone used a universal cable to power the starter with 12 volts....
It’ll be running by then.Maybe when I come thru there in July, I could look at it?
I know that, I’m more concerned that I have it connected rightOMG Chris, Electricity does not care what color the insulation is!!!!!!
yeah, doesn’t sayThe service manual with wiring diagrams is your friend...
Can’t get mine to talk either.yeah, doesn’t say
Think so?It’ll be running by then.
Wife?Can’t get mine to talk either.
I think we're better off if they don't talk.......Much.......Wife?
I know soThink so?
I know so
