I am sure that was fun on that bumper made of real steel!Put my pretzled bumper in the hydraulic press yesterday. The toughest thing to get rid of is the twist. Dents are easy, kinks are tougher. I left it to think of what i can do to untwist it.
If it makes you feel any better hoppy, you’re not the only one dealing with a cursed car. That mini starter I got and put on Polara, second hit and it doesn’t work anymore. Pulling it out and taking it back for warranty today @halifaxhops
Morning. -8 this morning. Temp will be dropping all day to -17 by 5 pm. Damn.
Work on fargo,measure for a couple fish plates and see if i can get them in..
That should teach you not to pack **** in your trunk!![]()
Hook one end to something solid like a big tree. The other end a 30' chain hook the other end of the chain to the frame of your good truck. Back up as close to the end of the bumper as you can. Put it in forward LOW gear and then floor it. When your truck stops back up and check to see if the twist is out. If it is not repeat procedure until the twist is out. But don't do it in that frigid weather or the metal may crackPut my pretzled bumper in the hydraulic press yesterday. The toughest thing to get rid of is the twist. Dents are easy, kinks are tougher. I left it to think of what i can do to untwist it.
no, not busted, but they did screw up, promoted me, then realized they didn’t have the slot and after a year, demoted me as a “re org” and then randomly slotted next in that ranks slot but in a MOS I didn’t have, which left me stuck for years. And sad part, I caught them trying to do the same just last week.You got busted? That explains it then!![]()
mechanic? Hell I need an electricianThe Polara isn't cursed, it's the ability of the mechanic working on it that's lacking.... LOL! View attachment 1715470526![]()
Dam Karl your on a Rani roll!
Hook one end to something solid like a big tree. Put it in forward LOW gear and then floor it. When your truck stops back up and check to see if the twist is out. If it is not repeat procedure until the twist is out.
Karl we have a don't ask don't tell policy on this thread you know right?
What you do on the weekend is your businessThat sounds like I'm getting it in the @ss.....View attachment 1715470531
First attempt was blocking it up under the hoist with a car on it, didnt even fizz on the bumper.I am sure that was fun on that bumper made of real steel!
Pronounced “electchicken”no, not busted, but they did screw up, promoted me, then realized they didn’t have the slot and after a year, demoted me as a “re org” and then randomly slotted next in that ranks slot but in a MOS I didn’t have, which left me stuck for years. And sad part, I caught them trying to do the same just last week.
Bumper is off. Wont fit the straigtened frame until i get the knots out of it. I have a tiger torch,will heat it if i have to.Hook one end to something solid like a big tree. The other end a 30' chain hook the other end of the chain to the frame of your good truck. Back up as close to the end of the bumper as you can. Put it in forward LOW gear and then floor it. When your truck stops back up and check to see if the twist is out. If it is not repeat procedure until the twist is out. But don't do it in that frigid weather or the metal may crack
