Stop in for a cup of coffee
Rendering a video on the laptop as I sit here for the weekly review of occurences.:wtf::BangHead:
Ddaddy has been working on some images for me. Here is a black and white he came up with. Took a 69 Dart with a hood scoop and tail stripe and turned it into a 67 Dart with a stock hood like I like. Then he put a 67 grille in it too, all with his imagining skills.
Evening fellers, if anyone is around
Yes Rain, am around.
Made the transition to Florida now for the rest of the Winter here, so hanging out here in the shack, pretty much taking it easy after getting through a few challenges in the snow and cold in MN this Winter.
Feels good to back things off for a while.
Florida weather sounds good right about now
I'm still slowly working on the duster.
I filled up the master cylinder, pumped it and then held the brake pedal down with a dowel stick for an hour. Then pumped the brakes some more and they are actually pumping up. So I might bleed them and attempt to use in the yard.
I have had them dry out before and still come back. Brake fluid is hydrophilic, so I imagine it will evaporate like water ...... eventually
Sounds Good, making progress keeping those Moperrrs Runnin'
So George do you take the car down to Florida or does it stay up north?
I drive the full size Ford E150 van down, got a cot in the back so I can stretch out at the rest stops and take a nap.
Hit some fog on the way down just North of Atlanta, so I had to hang tight for a bit till 10:00 a.m. one morning till the fog lifted, then I could go again.
Kind of like having the full size van down here with the tow hitch on. Once in a while I have to hook on and tow a few things, pretty handy.
Morning all. Definitely over did it yesterday. Been up most of the night with back spasms
