Stop in for a cup of coffee
At least it isn't the gas pedal foot. I hit the agree as confidence!!
I broke my gas pedal leg once...
Just swing the cast over the floor hump and use the other leg to work the gas and brake pedal... (Drive an automatic...)
New sneakers for the Wizard just showed up. Valve stems are supposed to be here Saturday. I want to cut everything again right before I change them in case I run into any issues. Wheel bearings or ?...
Its tough to do. I once broke and separated my right shoulder. I had a five speed truck at the time. I taught my then six year old daughter to shift gears for me. She did that for six weeks one summer. She got a new pair of skates for her help. :thumbsup:
Was down to freezing overnight. Trying to warm past 50 today, but near 20 MPH wind is gonna keep it feeling quite chilly. Saturday is projected to be nice 60 and no rain. Bot otherwise we have about a week and a half before the nights stay above 40 and days above 60. Come on Spring!
Hmmm...
So PA has changed the way they report cases. They are now including 'probable'. Mostly applies to deaths I believe. I'm guessing they initially wanted to show low numbers cause they thought it would skyrocket. Now they want to justify keeping things closed. Plus I would assume high numbers means more FED funds...
Well, Chris, smoke is blow by, caused be a worn out engine. when cold you will not see it. A PCV valve will lessen it, at least you will not see as much, but will still be there... All caught up....
So, it cranks!
But wont fire!
What do i do now? :poke:Chris..
Well,
You said youself it needs fire! Get one of them long lighters and shove it in the #3 cylinder. Use a remote start and crank it and hit the lighter precisely at 2.7 seconds. :thumbsup: Disclaimer(This advice is for somebody's entertainment purpose only. Actually doing this may win you a Darwin award. Don't do it!)
Well,
