Then how the heck is that price including spray foam insulation? So the building is actually less not including the insulation, you are going to have to have done by a separate contractor?no, i have to put each up.
correct. the spray foam is done by a local company. I added it to my quotes since I'm doing that anywayThen how the heck is that price including spray foam insulation? So the building is actually less not including the insulation, you are going to have to have done by a separate contractor?
roughly 2400 for the smaller, 3200 for the larger oneHow much for the insulation?
That is very inexpensive around here..roughly 2400 for the smaller, 3200 for the larger one
Do you need insulation there?How much for the insulation?
Nope. Was wondering how much the actual building Chris was considering cost, delivered. So it was what he said minus the insulation...Do you need insulation there?
Well...He does if he wants to Air Condition it..........Do you need insulation there?
I was thinking that, only needed to keep it cool!Well...He does if he wants to Air Condition it..........
I agree.
I will add that i've been getting quotes for steel and wood framed buildings, steel is coming in about the same cost. However, with the same pitch, the snow load is 30% higher AND the building its rated for 165 winds, thats on 12 ft spacings. the steel comes pre-drilled and powdercoated as well. Wind rating on the wood framed at 9 ft pole spacings is 105mph. Both prices include spray insulation.
It’ll nearest tree will be over 100 feet away. But good thinkingHere's something that you may want to consider, will there be a potential of trees falling on it? I know, you can clear a buffer, but if you didn't want to I'd go with stick built. My neighbor has a metal building, a tree fell on it 2 yrs. ago and it could not be repaired. He had insurance and I think that's what "they" came up with so....
I have a ton of testers I want to sell, prob 40 or so. The distribs are seriously getting busy probably to a day show up in the mail to do. Had to take yesterday off kind of de compress from it. Was on the phone with 5 people yesterday word of mouth stuff, all high dollar cars. Unbelievable the way word got out.
Makes sense...Here's something that you may want to consider, will there be a potential of trees falling on it? I know, you can clear a buffer, but if you didn't want to I'd go with stick built. My neighbor has a metal building, a tree fell on it 2 yrs. ago and it could not be repaired. He had insurance and I think that's what "they" came up with so....
They should grow then. If no signs of life take one out and see if it is still firm, then it should grow.
I really need to go through some of the "other" parts I have and e bay them. I do have a few nos/nors pcv valves for mopars I need to get rid of.
Yup, I've got trees behind my Shop, on the neighbors property, big Oaks 100 ft tall....LOL...I stick built my shop...Here's something that you may want to consider, will there be a potential of trees falling on it? I know, you can clear a buffer, but if you didn't want to I'd go with stick built. My neighbor has a metal building, a tree fell on it 2 yrs. ago and it could not be repaired. He had insurance and I think that's what "they" came up with so....
Yes, I think he does. I'd get some from him, but I have a few squirreled away....Got any metal PCV valves????
So Joey changed the size ? how do I make em smaller ? I know, thats what she said, Karl....
I left some of the thinner ones that long or longer. guess we'll find out.
PIA !!!!!Go into Microsoft Paint and resize them 40% and then save them under a different name to keep the high def original for later...
Moparts used to have a link on their tech area of a photo resize software, for free. I can’t seem to find it now but it was a good one, you just dragged your photo into and it asked you what size file and bam, 5 seconds and done.Go into Microsoft Paint and resize them 40% and then save them under a different name to keep the high def original for later...
Got any metal ones for a poly?I really need to go through some of the "other" parts I have and e bay them. I do have a few nos/nors pcv valves for mopars I need to get rid of.
Yeah. I’m leaning towards the steel. For one, it’s the same building design as the big 40x80 at the farm that was put up in 1992. That is NOT insulated and is rust free. And that building isn’t air or moisture tight. But it has sliding doors, mine will be overheard doors and air tight. Plus the steel trusses are Rated for 6000 pound vertical hoists.Nope. Was wondering how much the actual building Chris was considering cost, delivered. So it was what he said minus the insulation...
