And another. This one was in "Early A Body" before I moved it.Yep, probably move it to lost and found.
Wheel & Tire size
Enjoy the sun and protect that head!!Getting some fertilizer down on the lawn now. Got a 15k sf bag, and a 5k sf bag. A lot of lawn. Nice here......80 deg, and sunny. Got my shirt off trying to regain that VN Suntan......
Hey !!! I gots plenty of Hair up there still. I choose to shave it each day....Women absolutely LOVE it.....Enjoy the sun and protect that head!!
ANother. This gasket catalog was a Mopar part before I moved it. LOL[WANTED] - McCord gasket catalogThis is what I spend the majority of my time doing on here. Moving threads to the proper location, I move so many I stopped telling them where I moved it to. Figure heck they will find it.
Hahahahahaha, Im not referring to that one..Hey !!! I gots plenty of Hair up there still. I choose to shave it each day....Women absolutely LOVE it.....
Ha, She is Viet, but French indoctrinated....I let her Shave me before....I Know TMI...LOLHahahahahaha, Im not referring to that one..
Uhhhh Yeahhhhhh...So I tried the poly again but the battery cables were weak, really weak so I went through and changed them with some used but much healthier cables I had laying around
Still dead as a rock.
So I get under it and I feel there greasy *** starter for connections. The solenoid wire was loose then I realized the whole starter is loose.
So I pull the starter and find the nose cone broken and I test the starter...... dead
For as runny as it is, I doubt it will clog anything. I think most of that fuel is from 2016 when the previous owners brother put in a few gallons and tried to get it going to run into the same problem with the starterAlways dump the fuel first, if it has been sitting. Probably have varnish in the carb now................
The engine turns over easy with a screwdriver
So I install another starter I had laying around, a known good one.
I jump the solenoid and for the first time in over 20 years. WIIIRRRRRRWIRRRRWIRRRR.
so I crank it a bit in hopes of getting the oil pump moving some more and as it's cranking i smell varnish. The fuel pump obviously still works and gushing out of the carb so I'm getting a intake manifold flooded with varnish smelling fuel with a water like thickness.
I disconnect the fuel pump and let it pump into a bucket and poured fresh fuel down the carb and I had already connected a "hot wire" to the positive side of the coil.
It turns and bucks like it wants to start but just not enough yet.
I was going to spray it with carb cleaner but I'm out of anything flammable to spray in there.
Tommorw for sure it should fire
Depends on how much juice you have in the batteryA Chrysler starter does not go WIIIRRRRRRWIRRRRWIRRRR...
It goes WANANANANANANANANANA VROOM.....
Don't matter girl...Fuel can sit over winter and be no good... I just repaired a couple a small engines for a guy, Same reason . bad fuel. And..... Had to disassemble carbs and clean out... Jus Sayin....For as runny as it is, I doubt it will clog anything. I think most of that fuel is from 2016 when the previous owners brother put in a few gallons and tried to get it going to run into the same problem with the starter
they make and sell a non-flammable, non combustible carb cleanerThe engine turns over easy with a screwdriver
I'll see it now, the weird little juicer is off ignore.
Why would anyone want that weak *** stuff.they make and sell a non-flammable, non combustible carb cleaner
I have to go through the carb in any case.Don't matter girl...Fuel can sit over winter and be no good... I just repaired a couple a small engines for a guy, Same reason . bad fuel. And..... Had to disassemble carbs and clean out... Jus Sayin....
