Forgot one from the top but got the roof done at last.
Its pretty slick and SO simple.... basically a ball valve with a long stem grabber behind it. Screw the whole thing on. Turn the stem out. Close valve. Take the tool section off and swap in the new piece. Back on, Open valve, screw in the stem.I dont have that tool that changes them without losing the charge. But I knew the high side valve on this Honda was leaking, before it took it all apart. So I changed both schraders while it was empty. Even so....R134a is a lot cheaper than R12 ...
Good to hear you have it cooling.Got the R12 all in and he saw the schraders were leaking. Then he's like "if you get the valves I have the tool to change them" Huh, you can do that? Without taking the charge out? ...He goes and gets the tool and guess what? There's extra cores in the bag with it. Oh, didn't know I had them"... Swapped them out and the Duster AC is all charged and chillin'.
Thats what we used. We checked all the fittings, but maybe we forgot to hit them... they were both VERY small leaks.Soapy water works. Watch for bubbles.
Yup, I sold a bunch of them in the Parts Business, Just never brought one Home ....LOLIts pretty slick and SO simple.... basically a ball valve with a long stem grabber behind it. Screw the whole thing on. Turn the stem out. Close valve. Take the tool section off and swap in the new piece. Back on, Open valve, screw in the stem.
[Thats what we used. We checked all the fittings, but maybe we forgot to hit them... they were both VERY small leaks.
She is WAY to dated for you. But at our age its good to think that way!!Her date code looks good to me.
Tito's still not affected. Came home from today our Sunday two hour tennis drill class (850 calories) and only had a drinks worth.Disaster has struck! The aluminum beer can shortage has now taken out all availability of my favorite beer, Coors Extra Gold Lager. SOB!
The CEG can is unique in shape being narrower and taller than a regular beer can and with increased demand for all regular size aluminum cans, this one is last on the capacity list to be made and it is completely out of stock right now. Haven't been able to get any since the beginning of June and nobody know when it might come back. I only have a couple of cases left in my stockpile...
That's pretty slick!Got the stickers stuck. Lol. Looks right at home there.
You need to pull your pants up...your drawers are hanging out...Sign of a good day, not sure if I had every tool I owned out or not, but darn sure got close!
Ouch!Well motor torqued over, caught and bent fan blade destroying the radiator in my truck. Oil pressure hot at 800 rpms dropped to 8-10psi and valve train started knocking.
Probably a good plan. Sometimes it’s just not worth fighting what doesn’t want to be fixed.I think I am going to install the hot rod engine as this engine has been a 1 1/2 year pain in the butt.
And sometimes you just can't quit! Throw 100 dollars at at a 10 cent item just to win! I've done that crap way too often!Probably a good plan. Sometimes it’s just not worth fighting what doesn’t want to be fixed.
