Stop in for a cup of coffee
In reality we could supply a small town with what we have onboard.
Always loved the sound of that V-16 Detroit genset when I pushed the start button on that 250hp crusher motor :D
Not sure what KW we have at work. 100KW maybe? That's what I had at the cold storage. Just for backup lighting. Couldn't actually run any equipment on it. Same where I am now. Some of our freezer sites had trailer sized generators parked outside that could at least run some refrigeration. My larger plant had 5 NH3 compressors totaling 1550hp. I just closed all the doors and waited for the power to come back on.
My ex is a generator repair person in the Nat Guard... Deployed to Kuwait right now, due to come home in the next month...
Morning!
Rain in forecast again.
Another f150 with the same problem as the one i fixed yesterday. Should be easy. Hes the local gravel supplier, this will work out well.
Good Morning everyone. Hope all is well. Starting to feel the pressure to have everything moved. 3 weeks to go, but I am off from Thurs 3 July thru Tuesday, Jul 14. Got a pinch in my upper right shoulder blade area and so tired, can barely keep eyes open. Please pass the coffee....dark roast, black
Almost time to get it together.
Some shop cleanup and organizing again.
Start prepping for the weekend antics.
Hang in there brother. Been there done it. Your in my thoughts and prayers.
I lose track easily - are you the lucky bastard getting divorced? 3 weeks is plenty of time........ just leave the **** you don't want behind :lol:
Morning guys. Dr Appt. this morning. Just a check up. Then on to the local Dodge dealer to see if they will sponsor our event. I think I will get the grass cut this afternoon.
I took PTO for tomorrow so it's my Friday woo hoo! Tomorrow should be a good day, they are delivering my little tractor.
Yes that's me....only issue with leaving the stuff behind, is the house is being sold and I need the sale to go thru. Thanks though!!
We each have monthly 'inspections' My main one is ALL lighting. If a bulb goes out right over someones desk, or is flickering so bad they are going into seizures the other shifts will do them. Otherwise, I usually replace them as I can get to them. We have a LOT of bulbs. :BangHead: But it usually works out good as fill in work I can do when I want.
Betcha those underwater welders make some coin..........
Edit: Wrong Quote, This is in response to Steve's post...
