Stop in for a cup of coffee
Roofing materials dropped off.
I didn't keep a cooling system pressure tester for my old cars. I just bought one on Flee Bay.
What’s th problem?
Looks good from up top, crawled underneath and there’s some gaps between the panels, I should have butt welded everything instead of lap welded. Tempted to cut it all out and start over.
And if you aren’t Getting a good lap weld, you sure as fk don’t want to try butt welding!
Penetration is good. I’m thinking the panel underneath is warping. That or the cleckos aren’t holding tight enough, might switch the screws and see
