And if you aren’t Getting a good lap weld, you sure as fk don’t want to try butt welding!
That's what she said...
That or my welding sucks or both haha
What are you welding with? And put up some pics....Penetration is good. I’m thinking the panel underneath is warping. That or the cleckos aren’t holding tight enough, might switch the screws and see
That’s why I asked...lolKnowing Chris, he's using can of carb cleaner and a lighter to weld....
Good welder with good equipment = good welds. If one good and other OK= Ok WeldsGood call...
If both suck....
I don't know why, but that made me chuckle so much I was in sync with beavis.
If both suck....
To keep my floor pans tight till I tacked them I set a cinder block on them. LOLChris here is the clamp I was explaining. You can see remnants of weld on the base. That is where you tack it to the lower of the two pieces. Then simply screw down on to the offending raised piece. It will then succumb to your will. We call it heat and beat! (Que Karl)
Lincoln Pro 180 mig, Argon mix. .025 wire.Good welder with good equipment = good welds. If one good and other OK= Ok Welds
If both suck....
see above^. 30 amp, 240 volt, pushing the weld. No extension cord, 6 feet from the break box.OK, what kind of welder, how much voltage,size of wire. Circuit amps, running through a extension cord, Co2 or Argon/co2, pushing the weld or pulling? That's it so far.
Chris here is the clamp I was explaining. You can see remnants of weld on the base. That is where you tack it to the lower of the two pieces. Then simply screw down on to the offending raised piece. It will then succumb to your will. We call it heat and beat! (Que Karl) Thanks
I did that as well haha, problem is the back side. Talked to OMR, probably gonna use a floor jack and a 2x4 to put upward pressure on the the floor panTo keep my floor pans tight till I tacked them I set a cinder block on them. LOL
this is the before pic
