Stop in for a cup of coffee
Had a nice dinner at buddy’s place. 50 mile drive. Going past a wally mart, wife wants to pick up a few things.
Shampoo aisle. Wife walks into aisle and i wait at the end, keeping my distance. Some other woman, wearing a mask,grabs hair spray and sprays her hair! Wtf?
Next thing grabs hand lotion, opens it, pulls mask diwn and smells it! Three different bottles.
What in the actual frick??
Wearing a mask and pulls this ****? I really wanted out right then and there.
People suck
Dang, I just went through 189 pages of wix air filter measurements.
Seems the absolute lowest height I can get for my air cleaner is 2 " which will work perfect
The filter element I have now is the same as the 70 340 air cleaner and is 2 13/16"
That's a huge difference and will for sure clear the hood.
So my k frame lowering block made quite a stir,
....a disturbance in the force, it made....
I'm going to make some solid steel motor mounts that will lower the engine 1/2 inch and then i'm going to rotate the engine so the carb side comes down a 1/2 inch and then I'm going to save 13/16 of an inch with a lower air filter.
Together is almost 2 inches, if the hood don't clear that, then I might lower the k frame but I doubt it will get that far and clear the hood without lowering the k frame
If you rotate the engine, will the carb be tilted? How will it work right if not level (floats)
And, yeh... I saw the lowering discussion. It does mess with a lot of angles. Some might not matter, but certainly a bit more complex than just a couple spacers.
Hey MOPAR dreamers wake up...its only Friday!! Coffee is on, help yourself!!
Morning!
It is in fact Friday!
Fargo chassis gets a splash of paint, as well as cab floor. Then i can put cab back on frame.
All right I'm off to the other coffee group. I'll check back later.
and kill power
I have seen a carb back fire and it started back up and suck chunks of that foam material in the engine, it was a Ford so I giggled a little bit to my self
