Stop in for a cup of coffee
I actually have one of those that says "MADE IN CANADA" No idea what it is worth, cant be many out there only one I have ever seen.
I have a ton of MOPAR boxes, I used to give them to Dave for his collage displays then one year at Carlisle I was selling just point boxes for $5 each empty. I don't really care I use the points anyhow. Some boxes get really pricey especially the early Mopar script ones.
That is cool stuff. Nice there is a market for your trash! LOL
Wolfie had a idea what to do with the trash distrib housings also have a ton of them was waiting for cast al to go up. Steampunk mopar lamps!
Hey I got a question for whoever, 07 Cobalt started idling rough, pluged in the code reader wont even power up, tried it on another car reader fired up. The connector pins look fine any ideas? TJ?
Sounds like it isn't getting power through the ALDL connector.. Is your reader self powered?
I agree, No cheapo HF, never had a issue before with it or the car. Just weird, have no idea if there is a fuse or anything if there is I cant find it in the Haynes wiring diagram.
Morning.
Cool outside this morning.
A few oil changes today,my truck, buddys pickup and his neices car and his wifes car. Forgot i have to deal with the used oil, my oil drain is full, plus the drum. So i hope i can drop it off today. And pick up an empty.
I have a couple of plastic 55 gal drums, I pump to from my oil drain device. There is an oil recycling co that comes and picks up the used oil for free, when I call them....:thumbsup:
LOL I remember the gas station used to have a company that paid .05 for a gallon, pretty sure that is where Wolf brand oil came from!
Check the fuse for the lighter/accessory charging port. Bet its blown. Powers the ECM reader
Wow, was talking to my brother on that Marine AAV accident, I guess from the second water starts coming in, you have 8 seconds to egress. To complicate things, there’s two compartments, one on the right one on the left, the hatches are designed as to only allow one hatch to open at a time. Damn things literally are big coffins
Check your power point fuse, thats usually what powers it. In the owners manual it would be the aldl fuse.
G'd Mornin wrenchers
No self diagnostics? I have never bothers to get a scanner, cause only had Mopars for many years that the dash gives the codes. According to what I read the dash on Neon can actually show codes most scanners wont. Had one last week for a 'misfire on cyl 4' Poped the plug wire off and back on. Battery cable same. No code since...
A buddy heats his shop with used oil. I give it to him, he provides the drums. I wouldnt mind finding a waste oil burner,i passed on two, one for parts. I figure if i get 2 months free heat it would be worth saving the oil.
