Uhm I see two issues there Chris!
Crank Flex?Uhm I see two issues there Chris!
For SURE!!!Chris did you chase the head bolt holes also? That can screw you also.
LMAOBy the time the vaccine makes it to me, i will be dead and buried and my wife will be remarried and on her 3rd cruise with her new husband.
not yet, I did chase the main cap holes before I put the studs in back in.Chris did you chase the head bolt holes also? That can screw you also.
Used heat shrink but same ideaRubber hose to guard crank from damage. One slip and its start over.
I think it was just sitting at the time. It’s square in there now.Almost looks like it is rotated in there also or is it just sitting in there. I did that once really screwed up my crank. Had to cut it and get it re balanced also. Expensive mistake for sure.
Yes. I was gently putting each in to check deck height across the bores when I took that pic. No rings. Rod cap tight but not torquedYou do know you have to start in the middle and work out right???????
Crank is torqued down, clearance is .0018, I’ve got to do the rod caps yet so that .053 is rough measure at the momentHow can you check deck height without them all in and tightened to spec?
I’m getting to it. I took a dinner break and ran into Napa for more plastigage.I was talking rods? I have always done it with them all in and tightened to specs to ensure the crank is uniform across all the journals.
Because i bought the book? Used it years ago when I built my 451. It seemed to work okay then, don’t see why it won’t nowWhy noy you tube?
The book has you put a piston in holes 1,2, 7 & 8 to check deck height squareness. It also says to snug up caps but not torque yet.Why not you tube?
It’s not, the engine is rotated 90 degrees from the top. The arrow is on top when the block is rotated back straight up. I have it rotated so I can guide the rod down thru while pushing the pistonsShouldn't the arrow on the piston that points to the front of the engine be on the top and not the bottom????
Or are all the pistons the same and the arrow is on top for one bank and bottom for the other...
The arrow should point to the front of the block/engine....
look at the top of the pic. You can see the motor Mount bosses.Shouldn't the arrow on the piston that points to the front of the engine be on the top and not the bottom????
