Tim, What do they charge these days to Dyno an Engine ?Getting new date for Dyno time to put my 408 to the test......
Locally, it’s 150 an hour from the time it’s hooked to the dyno. Most have a 2 hour minimum. Not sure what it is in Tim’s neck of the woodsTim, What do they charge these days to Dyno an Engine ?
Not Mitch....My Shaft is Adequate ......
125 hour. 2 hour minimum. Includes hook up, break in, run, tune, run, tune, till the engine is dialed in or time is up...Locally, it’s 150 an hour from the time it’s hooked to the dyno. Most have a 2 hour minimum. Not sure what it is in Tim’s neck of the woods
One of the rare times CA is cheaper than here. But we also only have a few places in the state that can do it.125 hour. 2 hour minimum. Includes hook up, break in, run, tune, run, tune, till the engine is dialed in or time is up...
Locally, it’s 150 an hour Most have a 2 hour minimum.
Good to hear. You know, I had sciatic nerve issues because of a ruptured disc. It took a long time to get on the other side of that with my chiro but it has been really good for a long time now. My medical Dr. even said as long as I was getting relief it is better tan going under the knife.
Or they blow up your engine....
Just twist the screws till the motor goes POOF
Theres something i would never expect to see..I ordered some stuff for my room from the hotel yesterday. I ordered Lays Chips. This is what I got. WTF ???
No, it's Lay's chips part of the Lay over Mitch has been on for the past month...longest one way plane ride I've ever seen.You said Laid chips!
