Didn't know you were selling your next project.Posted some more pictures over at B Bodies.
FOR SALE - 1966 Satellite 4 speed Convertible
Got something else you want to work on?
Do you someone with that level of expertise who works on cassette decks? I have a TEAC 550 and a Sansui 3 head D-705 that need someone who knows more than cleaning and spraying with Deoxit.Hello All! Back from weekly water run, 2 5 gallons plus a tank of propane for the grill. Just about busted my turntable motor with those new split ring pliers, going to send the turntable to the "Dual Doctor", he's a pro out of Ontario, really good reputation on this equipment. He'll do a whole service to include the tone arm dampening fluid so I can let go of the lever without it dropping, clean/lube the motor. I've got an email in to him for quote, have done two clean and lubes on this turntable, time for a more in depth servicing.
Getting tired, want to start traveling some, Might not have time to complete this...Didn't know you were selling your next project.
Problem with both are, the rubber parts deteriorate. Might not be able to locate replacements....Do you someone with that level of expertise who works on cassette decks? I have a TEAC 550 and a Sansui 3 head D-705 that need someone who knows more than cleaning and spraying with Deoxit.
Still have 66 dart in pieces, AND my 67 440 Dart needing work.....Didn't know you were selling your next project.
Not to mention the 67 sport fury convertible 383 auto in the future.Still have 66 dart in pieces, AND my 67 440 Dart needing work.....
I replaced the square drive belt in a cassette deck with an o-ring. Worked perfect.Problem with both are, the rubber parts deteriorate. Might not be able to locate replacements....
This things need just a few tweaks. Speed adjustment, check head alignment, and the Sansui is having some control issues where the bottons don't do what they are supposed to. That may need parts. And thats why it cant be the guy with some belts and a can of deoxit. Been to a couple or three of those.I replaced the square drive belt in a cassette deck with an o-ring. Worked perfect.
Teac A-550rx?Do you someone with that level of expertise who works on cassette decks? I have a TEAC 550 and a Sansui 3 head D-705 that need someone who knows more than cleaning and spraying with Deoxit.
Does that have a 60 inch deck?
V-550XTeac A-550rx?
Apparently I can't PM pics. The same as what Mike just posted above
A bit, I compete with a 1900 Remington!@Sublime one you know much about old shot guns, like turn of the 20th century shot guns
With lacquer, in the heat, outdoors, you have to spray a section at a time and blend it together. Dries to fast to prevent over spray "dust" . I have found out....BUT. 2000 grit wet, and Mequires buffing liquid, blends together nice...
Well I just was given my great great grandfather’s old Humpback Semi auto. It’s in pieces and appears to be missing a few things. It’s an old Model 11. Wondering if it’s even possible to find parts for it. Googling as we speakA bit, I compete with a 1900 Remington!
