This is supposed to be good.Maple Vanilla coffee beverage this morning . A little Yukon Jack in there would make it a tasty warmer upper for later today in the frickin' rain .
I may try it. It may just work better and flatter. Probably take longer but I’m okay with thatI watched a body shop buddy do a quarter once. Miller MIG sitting right behind him and he has the 000 tip on the little Victor acetylene torch in his hand. Weld a little take the hammer and dolly to it while still hot, repeat. His preferred method, even had a little stand made for the torch so he could just hang it close by without even putting the fire out
Available in ‘restoration size’ bucket.I may try it. It may just work better and flatter. Probably take longer but I’m okay with that
On my satellite, I am going to make the weld right under the trim molding. the trim will cover it up. A lap weld, using a flange tool.....I could glue it, but I need it to look original as best as I can.....I should add that his pre-tack fit was remarkable, not a gap to be seen. Minimal filler rod used.
Start with quality, end with quality..start with crap, tough to make it look like quality...IMOI should add that his pre-tack fit was remarkable, not a gap to be seen. Minimal filler rod used.
53 now. Prob high of low 60s. Beer run and maybe mow the lawn.. Making some breakfast now. BACON!No pasture pool today? Be a crappy day for it here anyway. 58° and raining not my idea of good weather for batting a helpless ball around
Practice!I may try it. It may just work better and flatter. Probably take longer but I’m okay with that
You have to be more precise using butt welds. Lap gives you more room for error. IMO. Setting up I mean, cutting the panels to fit....Butt weld. Thats all im going to do from now on. Lap joint traps moisture unless its 100% sealed inside too. Watched a guy on youtube do 1/4’s on a satellite. Did a nice job and took very little filler after.
There is a reason the factory uses lap welds....al tho they have gotten very good at fit and finish...You have to be more precise using butt welds. Lap gives you more room for error. IMO. Setting up I mean, cutting the panels to fit....
Honestly. If I were to do this again, it would be full quarters and spot weldsYou have to be more precise using butt welds. Lap gives you more room for error. IMO. Setting up I mean, cutting the panels to fit....
I have full quarters for my Satellite. Debating how much of them to use.....Honestly. If I were to do this again, it would be full quarters and spot welds
Only as much as needed. Save the body lines and door striker pillar if you can.I have full quarters for my Satellite. Debating how much of them to use.....
Was thinking that,Only as much as needed. Save the body lines and door striker pillar if you can.
Yeah, it's good to have some Pink Floyd to listen to while you work....
BUT he is a real nice guy......This Floyd's not pink.
