Stop in for a cup of coffee
What did you get? I bought a new Dyna grille from Home Depot, 5, 12,500 btu burners and one 15k btu sear burner/grate. Thing gets hot fast. If I turn all them on high, it hits 750 degrees in about 5 minutes. When cooking, I use just two burners on low and alternate which ones I use each time. It also has a smoke box and a side burner but I never have used a side burner when grilling. Stainless burners and I upgraded to the ceramic coated burner covers.
I bought a Weber Spirit. I had such good luck with the last one. And replacement pieces are readily available like flavor bars and grill grates and the like.
Woke then Demon from its hibernation. It ran great and felt so good to bring it home.
Fire table assembled and tested.
Throws some decent heat too. Wife’s happy!
In case yall ain't heard it yet. I'm sneakin up on gettin the tune right.
If it makes any difference, I just knocked off a piece...:lol:
Good Morning All! Got the fruit trees in, cherry, apple, peach. Also a gooseberry and 3 blueberry bushes plus the fencing. I want to add irrigation then it will be more hands off and I can put some hands on my Duster lol!
Nice!!! That’s something I attempted yesterday but the ground was too wet for me to get onto my property safely without getting buried
Yeah that is a show stopper. For us we hit wet clay/sand mix but had enough quality soil to mix back in the hole to get it done. One good thing was that the posts for fence and trees were easier to drive in. Looking forward to seeing your tree once you have the chance to plant it, post pics.
I planted 3 blueberry bushes Fall 2019. Got some berries last year, but mostly fed the birds. covered them with burlap for Winter. Near or above 80 next few day, but back to 40 by Sat night. After that should be good to uncover them. Then I need to come up with a better netting setup than what I had last year before the berries get nice.
@halifaxhops Ray, i opened up my distributor, one spring was stretched. And the tiny pin it hooks on was worn almost all the way through. Also the slot on the shaft was worn badly. Pulled my spare and robbed parts to repair it. Thats fiddly work imho.
And it turns out the vac advance on it was good, whomever put the vacuum line on it cross threaded the fitting. Im still going to use the new one, but this gets me closer to a better running engine. Definetly needs all the help it can get. All cleaned and oiled, ready to fire again.
