Stop in for a cup of coffee
.@Mopar Tim @halifaxhops Floyd and his helper.
Grille back in, amber led in the skull and its good to go until its not. Lots of junk came out of rad. Same with the block. Now all i need is the vacuum advance from Ray and i can get the tuning squared away. Its awesome he had a rebuilt one.
I love the skull! What did you finally decide on the tailights? Last I knew you were debating between styles? You should post a pix of the skull on the same thread where the guy melted down over the radiator not rad comment. He would have a fit if you called the skull a side marker! Hah! Now back to my scotch
The small oval taillights below the bed,mounted horizontally.
I need to come up with a panel to put the bigger lamps on.
Working on Dart. Waxing it. Woo Hoo......It is nice to have it nice enough that wax has a meaning!:thumbsup:
So aparrently i have to assemble a propane firepit. So back out to garage ...
I was suprised. Bought a grill at Home Depot. Tried to get it cheaper if I put it together myself. Nope, same price. Took the display model home and had it lit in 5 min ! Score.
So a professional welded quoted me 175 dollar fee plus 100 bucks per hour to weld them in. How long should it take to weld two quarters in?
The shop that did my patch panels used a wire feed braze machine. Lower heat and there was still a few spots that warped.
What did you get? I bought a new Dyna grille from Home Depot, 5, 12,500 btu burners and one 15k btu sear burner/grate. Thing gets hot fast. If I turn all them on high, it hits 750 degrees in about 5 minutes. When cooking, I use just two burners on low and alternate which ones I use each time. It also has a smoke box and a side burner but I never have used a side burner when grilling. Stainless burners and I upgraded to the ceramic coated burner covers.
