- Joined
- Mar 17, 2018
- Messages
- 13,401
- Reaction score
- 30,477
Well if it is good enough for you it is good enough for us! Hah!5 hours later, dont mind the crappy camera work and shitty audio..https://youtube.com/shorts/akE32J-8ejI?feature=share
You know, I could come over a day to help you with brick drive.....Drive up from Rays, and put in a day, then drive back.....Let me know....Put a fork in me.
Did everything today except what I wanted to.
Reality is it needed done. Have a waterfall again. Still need to rebuild it though.
Did a lot of weeding still not done. Watered everything green house veggies are doing ok.
Managed to get 50 plus bricks in drive way.
Only about 600 or so to go.
So, what you are saying is you want someone to throw bricks at you?Appreciate that .
I just hope to get it done before then.
I can do it in a few days a most if I have someone feeding me bricks.
Its the up and down back and forth that takes up the time.
@RustyRatRod @halifaxhopsSo, i think i will need to tear the thermoquad down and clean it. Im positive the idle circuits are plugged. Likely the accellerator pump is boogered too. Any tricks,tips or excellent advice to offer?
This one looks untouched,maybe 45,000 miles on it.
So, what you are saying is you want someone to throw bricks at you?[/QUOTE
Would be better then some of the things I've avoided in my life.
That is a funny line though.
Flat rubber seals might be sucking air.....So, i think i will need to tear the thermoquad down and clean it. Im positive the idle circuits are plugged. Likely the accellerator pump is boogered too. Any tricks,tips or excellent advice to offer?
They do get heavy....Well glutton for punishment that I am.
I went back out to prep for tomorrow. Try a different approach.
Maybe I won't have to get up and down as much.
Damn these bricks are heavy. I need to weigh one.
7 to 10 lbs, my guess...........nearer 7Well curiosity got the better of me. So I did it the scientific method.
I weighed myself then with the brick.
Now I know we're the expression thick as a brick came from.
Anyone want to guess?
Put both those numbers together. Seriously!7 to 10 lbs, my guess...........nearer 7
Im going to order a carb kit,and get after it. The bowls wouldnt fill until i rapped on them. Will see what happens after they sit with gas in them.
17 lb.11 pounds.
17 lb.
Heavy as hell.
17 LBS, really??Put both those numbers together. Seriously!
I'll bring one to Carlisle.17 LBS, really??
Brick him in the head and see what he says. LMAO
