Chris what gauge you using to measure this, just caught the 5/20 shoud be lower, mine is with 20/50 right now.
Picture of your throttle/kickdown linkage at the carb? You running stock or Lokar?I think I have the fix. 66 has a fixed kickdown setup. I have modified a later setup. I need to make the slot longer. On the carb linkage. Not coming forward all the way. Already adjusted as short as it will go....
Looks great.
It’s an aftermarket SunPro mechanical gauge. If you all think somethings up, I have a brand new Mopar performance mechanical I can swap into it and see if it changes.Chris what gauge you using to measure this, just caught the 5/20 shoud be lower, mine is with 20/50 right now.
Leave him alone he thinks it is a TUNER!Chris, 10/30 in the poly.
He said he was running a later factory kickdown. Not sure which one or how it differs from the '66 kickdown.Picture of your throttle/kickdown linkage at the carb? You running stock or Lokar?
If it reads zero engine off and 50 psi on the highway then seems unlikely the inbetween would be that far out of wack on a mechanical. No?It’s an aftermarket SunPro mechanical gauge. If you all think somethings up, I have a brand new Mopar performance mechanical I can swap into it and see if it changes.
Like drinking coffee?Hell isnt 5/20 a enging flush?
Probably isn’t.Something aint right then.
LOL.Dam Matt WTF is a centistokes? Seriously have no idea? Sounds llike something dirty a midget would do.
centipoise LOL thanks for dumbing that down, reay lost. One day explain it to me. USING CRAYONS so I get it!LOL.
viscosity units. another one is centipoise
Lower numbers are thinner.
