dukeboy440
This is what happens when daddy get to go clothes shopping without the wife’s supervision
I have a high flow water pump. Needs a high flow thermostat. NAPA does not carry one of those......Why not just go to the local Napa....
AhhhI have a high flow water pump. Needs a high flow thermostat. NAPA does not carry one of those......
Well summit delivered new thermostat real quick. Too bad it is the wrong one!! Shows for 318 to 360 mopar. Nope. To small......
Love the new avatar.
Any one know why they stopped putting the spring in the lower hose?
Yep, usually in the machine at the gas station men's room. Remember?Do they still make the ribbed for her pleasure style?
She was a hottie!Love the new avatar.
Cost?Any one know why they stopped putting the spring in the lower hose?
I would always pull the old spring out and clean it and reuse it. Even saved em from junk engines....Cost?
Wish I had one. Cheap insurance....I would always pull the old spring out and clean it and reuse it. Even saved em from junk engines....
What’s the intended purpose?Wish I had one. Cheap insurance....
Well, let me tell you. At high RPM's, it prevents the lower hose from collapsing. Pump sucking more coolant then can flow thru the radiator ...Lower hose can suck close, without the spring....What’s the intended purpose?
Hmmm well I will have to start checking the hoses at the junkyards for themWell, let me tell you. At high RPM's, it prevents the lower hose from collapsing. Pump sucking more coolant then can flow thru the radiator ...Lower hose can suck close, without the spring....
Thats a manual shifter.
Some friends are. At least one 900, a Sonnet, a '67 96 left between the two brothers. But I dont think they need anything.Since you guys have helped me alot. Anyone here into old Saab and Volvos? I'm might know where to find old parts......
YesAny one know why they stopped putting the spring in the lower hose?
There's an earlier and a later thermostat housing and the opening size changed.
Brave man. Lol
