Double flare on one end and bubble flare on the other. Double Bubble. Only you old guys will know what i am talking about. I sold a lot of combination kits that had dies to do both.
Speaking of double bubble....
where?Hey you will Love this trash guy asked me to stop teling peope about what happened. Sure Get the **** out of here you other then honarable discharged dirtbag! NOW! I used to like you. Free game I aint lying and people should know. Pretty funny actually dog with a tail between its legs.
Drive by!
Thank goodness for that thenYou're safer with 93 octane than 87.... 87 octane burns better and ignites faster than 93....
Drive by!
That's a pretty view.
So,… putting up a billboard?trash guy asked me to stop teling peope about what happened.
Umm, wow…So as you know Classic Industries sent a anti sway bar kit that does not fit early A bodies. Got them to return it, and I mailed it back to them. On the way home from Boise, I get a phone call from them. Hello, yes we received your sway bar kit, BUT on inspection it looks like it has been installed. Don't forget I sent them pictures of it installed showing the fitment issue. And we have a policy of not accepting returns that have been installed. WTF?? I said, but it does not fit. They said, I should always verify fitment and applications before installing the part. Are they kidding me?? I asked for someone with a brain. I told them the part shows that it fits my application, but it does not, and there was no way to know this without trying to install it. Sorry sir...I said, screw you, I will let pay pay issue me my refund....you guys are nuts......
Last thing I will ever buy from them.....EVER!!!!!!!! Conversation last longer then that, but you get the gist....Umm, wow…
Same turds that sent me the trans cooler lines with the wrong style fittings...Last thing I will ever buy from them.....EVER!!!!!!!! Conversation last longer then that, but you get the gist....
I’m actually a bit surprised it didn’t ignite the gas in the line and travel back to the tank where a fresh 15 gallons of 93 octane was
It is hollow. A tube. Heat treatedView attachment 1715783758 Make a keyed sleeve which must be long enough to compensate for the misfit. Cut the inappropriately sized sway bar in half and mill a keyway for a woodruff key in each newly cut end. 2 set screws on each side of the sleeve. Adjust to fit. View attachment 1715783758
Makes perfect sense.We used to be allowed to burn our leaves here in the old days... Once in a while we would take the easy way out and throw some gas on the leaves to get them going....
When we threw 93 octane on them, it did not light right away, a slight pause and then poof!!!
When we threw 87 octane on the leaves, no pause ---> POOF!!!!
The lower octane is more flammable and burns easier...
Octane is the resistance of gas not to burn... The higher the octane, the harder it is to burn.... The lower octane, the easier it burns...
That's why high compression engines need high octane so they don't pre-ignite early from the higher cylinder pressure...
When i get to cobbling one up for the Fargo, thats what is gonna happen.In that case. Find a hunk of pipe that fit around it and weld it together
They make hollow sway bars for A bodies. You can buy them right off the shelf. They’re chrome moly and thick but weigh less than traditional solid sway.I don't recall ever seeing a hollow sway bar. It's basically a torsion bar made to twist to some extent and transfer some force from one side to the other. My experiences with twisting pipes in a torsional fashion never ended well in the long run.
