Stop in for a cup of coffee
As much as you paid for that thing, I’d be sending it back
I am not going to throw around any **** about the build quality. It may be the pan was not sealed correctly. Which is on me......BUT with the oil on the flex plate, doubtful. BUT possible still.............Does not leak till 5K RPM. Then it pours out....
I know you said you have a pcv. But I would start back there. High rpm leaks are generally caused by excessive pressure..
Yep agree but...
Sooo, i regeared it. Havent road tested yet. Letting sealant on diff cover cure. 2.71,the gears that were in diff when i pulled it out of the 75 D100.
Vent is too clean. So no excessive blowby. If its the pan, could you jack up front of car and add a couple quarts to get the level up past the pan rails?
At least to rule it out.
Yep. I think it's more a vent, then rear seal problem.
Tim if you have a Vac/fuell pressure guage some how get it on a valve cover and see if yoy have crankcase pressure at RPM, Had a Chevy that did that, had to go with a larger flow PVC valve because the vacuum dropped at RPM. Rear seal if bad willl usually leak at most RPM. That valve you show looks like the same as on a early slant.
Ok ok I'm here. Went out to make coffee and we were out. What a way to start the day!!
Quick run to Mickey D's and all's good.
Good Morning!!
LOL I get six cans each time I am at the commisarry. On my last one now! But have a few bags of Steves! Love that stuff but high octaine!
So managed to get the doc to squeeze me in yesterday afternoon.
X rays today.
Have one of those neck braces to wear. It helps some.
See how it goes.
Said he couldn't give me much for pain. Except what I already have.
I told him no problem I have a Spanish friend who has a white woman supplier.
:rofl:
