You found another I see. You have quite a collection and that one looks pretty solid.Morning every one! Just finished lunch. Four hours and then start to tearing apart the next Dart Charger.
Thats a start.I guess I didn’t post it, I thought I did.
wires completely toast:
Alternator all the way back to the firewall
Horns all the way to the horn relay.
the ammeter wire all the way to the bulk head.
The ammeter wires under the dash(I’m guessing when the fire happened, it grounded something and juiced it?)
Headlight harness on passenger side.
Coil positive wire.
Water temperature wire
Oil temp wire
The blue wires on the ballast resistor mounted on the firewall
Voltage regulator itself melted.
not counting the rest of the damage:
Fuel pump,
Alternator
Plug wires
Upper radiator hose
Belt.
Washer bottle
Horns
Valve covers
fuel lines
My wagon and this car is the only ones I ever had with zero rust! I have start to like that!You found another I see. You have quite a collection and that one looks pretty solid.
Hey, if some wants to talk about their morning BM, there is nothing wrong with picking apart a failed wiring harnessThats a start.
There is no ammeter wire in the engine compartment.
It can't all be equally damaged. There probably are clues to what began it, how it spread etc.
I don't want to fill morning coffee with post portum analysis.
Set up a conversation that anyone is welcome to join.
I’ll probably do that this evening, I need to get pictures and then go from thereThats a start.
This seems to be more typical of what really happens. A little chaffing, a little wear, sometimes a mouse nest.Many years ago a friend had a 68 charger, another guy offered to wire in a stereo, smoked the wiring from fusebox to headlight switch. Was a mess.
Had a similar one with a kenworth,dash harness burned. 70 some-odd wires to replace.
It was a metal clip in the dash that rubbed through. Wiring harness sat on it,in its proper retainers. That one was a mess.
Exactly.Yet after all the discussion i did wire in the original ammeter in the Fargo. It was in great shape so i figured why not.
Our Gov is too busy changing his mind on othe random decisions he and his people have made.New Jersey, just announced a drop in gasoline Tax.
Hey Pennsylvania, are you paying attention!
You're applying logic again.Water rates are going up in Pa. Supposedly to pay for infrastructure repairs WHY. Isn't the state getting free money from the Feds. For that?
Struck a nerve because while I've occassionally seen an ammeter fail, the assertion that ammeters cause lots of cars to burn down doesn't seem to have any basis in fact.Good Morning everyone. My comment about ammeters causing fires - mostly due to old wires, years of changes, loose dirty connections, larger alternator outputs with no upgrades, etc. Anyway, like I mentioned elsewhere yesterday, could be wrong - usually am.
I just wish someone like painless would make a plug and play factory harness. Year one is expensive but I may go that routeThis seems to be more typical of what really happens. A little chaffing, a little wear, sometimes a mouse nest.
Exactly.
Our legislature is too busy dealing with their leadership chasing imaginary boogeymen.
Today's paper is the best. Philadelphia's leaders are blaming each other and other cities for the lack of trust and cooperation in Philadelphia.
Well that's progress. Now that they have identified the other guy as the problem, cooperation will be right around the corner.
People beleive it, and then go hack their harness with a bunch of cheap dollar store crimp connections and think they've done something good when they've done the opposite.
MAD's recommended hack has design flaws. As they are the biggest promoters of this myth on the web, that's the design most people adopt.
Standard bolt or something special - like AMC's hollow tip bolts?2011 ram for exhaust manifold. Fun fun. Supplies manifold,no bolts.
You don't need that till it gets cold outWhile cleaning up under the jeep yesterday, checked the heat riser to be sure it was moving free. It moved OK, but not real free, and the bimetal coil broke.
Bet it has less than 15,000 miles on it. New Junk
I wired it open.You don't need that till it gets cold out
Agree..............MAD's recommended hack has design flaws. As they are the biggest promoters of this myth on the web, that's the design most people adopt
Hollow tip? No. Got all bolts out and removed 1 broken one. So 1/2 done. 1 hour, not bad. Not bad at all. Waiting for delivery, 10:00.Standard bolt or something special - like AMC's hollow tip bolts?
Loose connections at amp meter. OR insulators failing grounding out the hot lead...the assertion that ammeters cause lots of cars to burn down
I know Chrysler kept the ammeter thru the early 80s, when did they steer away from itLoose connections at amp meter. OR insulators failing grounding out the hot lead...
They Should have kept them ALL............I know Chrysler kept the ammeter thru the early 80s, when did they steer away from it
late 80's, I think....Trucks...I know Chrysler kept the ammeter thru the early 80s, when did they steer away from it
Its more complicated and expensive to implement with an electrical system designed for EFI.I know Chrysler kept the ammeter thru the early 80s, when did they steer away from it
Sounds right. I'm pretty sure the Ram350 I drove was an '87 and it had an ammeter. dumper and plow were both wired to the battery. At the time didn't understand why so much current would flow through it when the raising the bed.late 80's, I think....Trucks...
All this talk of wiring woes, has me thinking I need to implement a fuse on my 66. Everything inside the car, runs off fusable link. The Amplifiers in the trunk have a 100 Amp fuse. The headlight relays are fused, BUT the line from the ALT to the batt is not. I have a 100 AMP Alt. Modified wiring is used. No Amp gauge.Sounds right. I'm pretty sure the Ram350 I drove was an '87 and it had an ammeter. dumper and plow were both wired to the battery. At the time didn't understand why so much current would flow through it when the raising the bed.
'85 was the last year for AMC's Grand Wagoneers to have ammeters.
'86 was the first year of a redesined wiring system. Power distribution began at the starter solenoid. Lots of fusible links.
