Come over and fix mine. LOL I put a defrost timer in mine, the freezer is still not cold. That did the trick last time. Same MO
Since the repairman stiffed me last week, I did some searching on line and found this web site that was very helpful... Here it is:
Appliance Parts Pros.com Discount Appliance Parts – Since 1999
enter the make and model number of your appliance, then it will bring up a page with exploded views of the appliance and its different areas/systems, like this... Clicking on and open in a new tab for the proper system will open a tab with the exploded view in a larger better to see picture, then click on the picture to expand it even more... You can save it to your computer for later reference...
Go below the diagrams, there are buttons describing different failures of the appliance, click on one of them that best matches your symptoms and it will bring up a list of parts that can be the problem - with the most likely offender first, and then the next possible causes as you scroll down...
Here's mine:
As you can see, it lists the most likely component first, then some feedback from others on the problem, the one I highlighted fit my symptoms exactly... Read the comments and follow what they recommend...
These comments fit my problem and I followed their advice... The next part listed for my symptoms was the temp sensor and it was backed up by the two feedbacks I circled...
Here's a close up the first feedback, notice that the orange number is the amount of people that found the post helpful:
Here's one of the second feedback that matched mine... This guy mentioned the repair videos for the parts...
Under the listing for the different potential parts that may be causing the issue, there is a link for a video to show you how to replace that part... Very helpful, but may not show the exact model you are working on, but will give you the jest....
Here's the one for the other part that I replaced:
So since the most common causes for my symptoms were caused by the defrost thermostat and temp sensor, and they weren't too expensive (especially compared to the cost of a repairman), I ordered one of each... Under $50 with shipping...
I did look up the parts for my fridge on the GE website and found them a couple of bucks cheaper and they were 'genuine GE quality guaranteed parts' so I ordered them from GE... But you can order them from AppliancePartsPros.com as they are not too much more expensive and I see some feedback that they shipped quickly - parts came a day later for some of the people.... The GE parts took 3 days to arrive, so if you're in a hurry to get it fixed the couple of extra bucks for the appliance pro website isn't that unreasonable and it's nice to support them for posting the great info....
So go ahead and give it a go Mike...
