Yeah, "Camera On" policy here... Keeping people engaged
We don't have that thankfully. I know 80% of people in the meetings are working on other things. You can tell when questions are asked and it is nothing but crickets.
my 24" header mufflers "should" be here today and if so, I will be driving it to auto shop to get it looked at. My teacher recommended not to buy jets yet until we verify the power valve is fine. He thinks the 67's sound pretty ok for my current setup.Hey SS6, thought about a couple things with your setup.
1. That's a huge change in main jetting. Be prepared to pucker when you take it up to highway speeds!
better yet, be prepared for the engine to rev and die. Make sure you have some room to coast to a lower speed and then it will catch and/or put it N and restart.
2. Get some collectors on the exhaust and the combustion should clean up. Carburation may appear to change as well.
Idealy A length of around 22" from the ends of the primaries, or a multiple, like 44. Atmosphere is shoving hot exhaust back into the cylinders. Don't be surprised if you see exhaust residue in the intake. If its all the way up to the plenum, that's not good.
Have fun learning
Nah, busy studying for another cert that could triple my salary
And I'm awake. Pool duties this morning. brush it down and change the filter. I'm happy. 1st time ever the water has stayed clear for more than 3 weeks. $hit canned the cheap Chineseum clorine...
Water would begin to turn green with algae within a week..
My late coffee walk, spring is in the air as I look east in to a pasture.
Good morning from Northeast Arkansas.
Have a good trip @toolmanmike
Need to put cyanuric acid in it. Stabilizes chlorine in hot weather pools...Water would begin to turn green with algae within a week..
Make a move. Which I’m trying to do anyway. Which believe it or not, is proving more difficult than i thought. I’ve had several offers but there’s big enough issues with all of them that I’ve turned them down. But something will shake free. Eventually. My career has a -12 percent unemployment rate BEFORE Covid started.Same company or would you have to make a move?
The PH level has been good since using the good Japanese Chlorine...Acid levels in pool very important also. I think muriatic acid was the acid of choice at one time. Also handy for eating the zinc off galvanized pipe for welding in it's undiluted form and cleaning the concrete off filthy mixer trucks .
Where is Sir Hops and Skips ???
Spend a couple $ on Mike Urich & Bill Fisher's Holley Carburetors or the slightly later version. Holley Carburetors and Manifolds HP Books. Holley part No 36-73.my 24" header mufflers "should" be here today and if so, I will be driving it to auto shop to get it looked at. My teacher recommended not to buy jets yet until we verify the power valve is fine. He thinks the 67's sound pretty ok for my current setup.
That is one beautiful car, had one in 74, 318, auto, buckets. Wish i still had it.OK guys, found this one for sale.
