Ok then let's back track . You have new mounts correct? And they are the same or different from the old ones?It's our of a 65 Barracuda
Can you use the old ones.The "set" are two identical mounts. Pattern same as the right side only... but they're almost an inch thinner than the current mounts.
Single bolt stud through the K, 2 bolt studs to the engine
Current K is not a spool mount
Ok back up.The "set" are two identical mounts. Pattern same as the right side only... but they're almost an inch thinner than the current mounts.
Sorry I'm getting lost here.
Nova is up by 6 with 25 ticks left. If anyone cares
Searching using duckduckgo for
insulator 2264140
1963 1964 1965 1966 Valiant Dart Cuda NOS MoPar RFMOUNT | eBay
"insulator 2265018"
turns up this
Front Engine Support Insulator# 2265018 / 2406705 - LH - A - Body - 6 Cylinder - 1962-65 - NOS - Blue Star Performance
That's great Tim!Well got new gas gauge reading pretty good. Full is full. 1/2 is correct and empty is almost perfect. At least on the bench with a 5 volt power supply...
Short biscuits!
It's the last 1/4 tank that matter the most to me to be accurate......and that is the "dead' zone. not a lot of difference.... Gauge has 2 adjustments on it, and you can do some adjusting on the sending unit itself... This is assuming full up is full in the tank and straight out is half. And full down is empty. Seems rigjtThat's great Tim!
Dana was testing using resistance, and also using a '67 tank which may be different enough to measure a little different.
Short biscuits!
Guess that one is supposed to be for the right side.
I don't how that works out on a '66. All (two, three?) measurements that were posted using a tank used a '67 up style.It's the last 1/4 tank that matter the most to me to be accurate......and that is the "dead' zone. not a lot of difference.... Gauge has 2 adjustments on it, and you can do some adjusting on the sending unit itself... This is assuming full up is full in the tank and straight out is half. And full down is empty. Seems rigjt
I think thats good. Its something 10 ohms to 73ohms ? (going from memory) so would think some voltage even at the extreme.Almost full down. Funny thing when full down empty there is still .831 volts at gauge..
It's the last 1/4 tank that matter the most to me to be accurate......and that is the "dead' zone. not a lot of difference.... Gauge has 2 adjustments on it, and you can do some adjusting on the sending unit itself...That's great Tim!
it is....I think thats good. Its something 10 ohms to 73ohms ? (going from memory) so would think some voltage even at the extreme.
That's enough power to heat the gage resistor a little. ?
Well, gauge is not linear for sure...Like I said, the last 1/4 to me is the most important...I don't how that works out on a '66. All (two, three?) measurements that were posted using a tank used a '67 up style.
The top portion is shaped fo the spare tire well.
