You need dis-saves fiddling with the handle. I need to make up a few more. View attachment 1715913759View attachment 1715913760
Oh yeah.
Flat stock with a slot ground out?
Need me to stop and give you a crash course?You got more amperage rolling there at 180. Mine is a little ole 100 A ...
I'm psyched to teach myself how LoL
Glad I could make a lasting impression.
Around 6 psi on gas.That'd be cool. Let me figure out the gas and I'll hit you up
Want to get reinforcing plates on the LCAs. Seems simple enough
I will show you how to set tension on the feed rollers when I see you. You don't want to be crushing the wire out of round.
Your a smart man., you will get it.Thanks Wolfie
Trying to sponge up as much as I can.
Do yo have clamps?Thanks Wolfie
Yes.Oh yeah.
Do yo have clamps?
Let me get some picks.No... looked at some today but hadn't done any research on what I should initially get
Yep been there.View attachment 1715913882
Welding slag story 1
Imparted to us apprentices by our instructor. He was master mechanic for a local construction general contractor.
One of their Cat scrapers the welds around the pivot point on the goose neck to the scraper can was badly cracked.
Welds had to be scarfed out with an air arc, 10' off the ground from a ladder and re-welded.
His welder associate was on it while the intstructor was busy with another issue on the tractor.
Ernie hears a crash and then screaming "ERNIE! CUT MY BOOT OFF ERNIE!"
Found his welder laying on the ground next the ladder holding his left leg in his hands screaming.
Big ball of slagg from the air arc got to his boot laces, burned a hole through the tongue of his boot and continued to burn a 1/2" diameter hole in the top of his foot.
Ernie cut the boot off and poured water over the foot to put the fire out.
Poor guy was off work 3 weeks while it healed up
My next opportunity I went shopping for slip on boots suitable for working construction.
Yep been there.
Have a hot one roll done your sleeve while on a 40 ft ladder doing overhead
Down the sleeve ,into the shirt on to the pants all the way into the boot.
Good times
I had a molten slag ball nearly miss mine. One inch to the left could have been bad news.Yep been there.
Good times
Mom said the best part of me rolled down dad's leg.I had a molten slag ball nearly miss mine. One inch to the left could have been bad news.![]()
That’s what I did. Works wellView attachment 1715913939 find a steel c clamp at the garage sale or swap meet, cut the stationary side off for the height you like and weld a piece of 3/8 or 1/2" strap on there, cross ways from the one showing, you may need the extra depth some time. Tack weld it to your work, make the welds, cut the tacks and on the the next time ya need it.
Raining cats and dogs and moose! And tunderin!Sump pump float hung up. Water in basement. Turns out the mrs was moving the hose that submersible is connected to and caused float to stick. At least shes learned to stop yelling from the bottom of the stairs. Chose to deal with it.
