I miss this Hot lady. She could lift the front left wheel off the ground.
Give my regards.
Which direction are you pointing him when he leaves?![]()
Our last dog Charlie was like that short or long ride he was ready.
He will love the pond.
Anybody know of a source for an air cleaner base that I can use on my OEM 225 air cleaner (9") that will accommodate my Holley 4bbl (5 1/8)
I want to give the engine more of a stock look as opposed to the 14" air cleaner that's on there now. I could also use the extra clearance with the brake system upgrade
What about the stock 68-69 a-body 340/383 air cleaner....
Coffee at Hardes at the Loves in Lansing is terrible.Walked into the store and the Loves coffee was better!
Hanging out washing clothes waiting for the Formula 1 race to end so I can get the TV screnesThe Loves side probably runs through the coffee at a higher rate so it's not distilled.
And only 1 lug nut per wheel![]()
I just cut out the 4 barrel base from a cheap air cleaner and welded it in in place of the 2 barrel hole in my original air cleaner. Pretty easy..Anybody know of a source for an air cleaner base that I can use on my OEM 225 air cleaner (9") that will accommodate my Holley 4bbl (5 1/8)
