Stop in for a cup of coffee
Whoah, gotta head into work. Glad I got my gas card yesterday as truck took $144 to fill. That would have been a 3 day of $300, feel lucky to drive a company vehicle for sure! Have a Great Day All! Hope you find lots of goodies in the trunk Frank!
Nice I just found some bales of barley straw for the pond. Only issue is 50 miles each way!
Off to the drag strip this morning to put up advertising signage. They are 4x8's but are the honeycomb plastic stuff with grommets. We use decking screws and washers with a cordless driver. It goes pretty quick.
Yep. Sell them in here for a few dollars
$20 or so
No. Get a front sway bar. Even a stock one.
Other than for getting the last fraction of perfomance for drag racing or rock crawling, a front sway bar is the best single improvement one can make to the handling.
Hey @halifaxhops ... need to replace the under-dash gauges (water temp and oil pressure) what brand should I be looking for? Eyes aren't what they were so wanting white dial faces so I can see them :rolleyes:
Oil I like the electrical better than the plumbed one less to go wrong. Want me to look around for a older kit?
For water temp and oil pressure get gauges with a 270° sweep, not 90° sweep, they will be much more accurate and easier to read...
90° sweep is ok for voltage and amps as they don't vary much...
Scrambled eggs with chopped ham and fresh asparagus. Dang, I forgot the diced onions.
These show up every now and then.
The tabbed LCA are more difficult to find, but tabs can be replicated and welded on.
[SOLD] - Early A sway bar and control arms.
Cool.. Thanks Mattax
The K-Frame is set up for the bar but the LCA's do not have the tabs. Future effort perhaps as at some point down the road I'd like to drop an early 273 in.
