Stop in for a cup of coffee
Morning Guys
Transmission Disappointment Syndrome.... :mad:
Not looking forward going through mine for the cuda. Hey if yu find a source for the full gasket/seal set let me know. The one for the loking cable housing is very hard to find.
Really? I have 3-4, you need one?
Morning Guys
Now you see why Chrysler went away from them. They were stout transmissions, but heavy and very setup/maintenance intensive. I wish I had time, I’d drive over and help you. Probably a 5-8 hr drive which isn’t bad.
I wish I knew more about those push button transmissions so I could help you Chris..
Thanks Mitch ..
I'm collecting information. 2 more "on car" adjustment options before having to drop it. Hopefully the cable adjustment and low/reverse adjustment are the ticket.
Dropping the pan is a pain because I have to pull the exhaust off the header to get at the one side. At least the torque converter is taken care of. That was not easy getting those last two bolts in up high on the driver's side. Had to support the transmission and do some prying to get alignment
@halifaxhops , I'll keep my eyes open for that. @dukeboy_318 said he found a good rebuild kit on ebay (???)
Thanks Chris.
If I get over my head into a teardown maybe I'll drag it onto a trailer and haul it out to the farm :thumbsup:
Thanks Mitch ..
Yep let me find that link.
the crazy thing about these transmissions, it’s almost always either something with park or reverse. It’s rarely the forward gears. But they are very easy to rebuild.
Nah, I’d just drive down. Be easier lol.
Hey are your cables leaking?
No leaks.. that's what started the saga. Replaced a badly leaking Park cable.... but everything still worked OK... then, oddly enough, when I replaced the transmission cooler lines everything just quit.
Hmmm that’s weird. Get everything adjusted and retry. You sure nothing got in the trans lines like dirt or gravel or something when you had them out?
Hahah. Absolutely :lol:
Don't think I didn't have one by the car when I first started the car after the carb rebuild
Get a CO2, The dry chem ones eat aluminum and paint. Ask me how I know!:mad:
Also get at least a 5 lb bottle. My ABC 2 LB barely did the engine fire.
No, nothing. I used caps to cover the open ends I wasn't working with...
Any chance that if the transmission cooler was clogged somehow that it would cause issues with hydraulic pressure build?
New cable? Might have done that initial strech they do when new. Double check the adjustment again. Prob something simple.
Definitely could. Filter could also be clogged. The right one come in yet
Yes. Filter and fluid replaced yesterday
I may try to bypass the trans cooler and see what happens
Chris aka Willie. I think you are overthinking this a bit to much. Double check the adjustments and if that does not do it drop the pan and look for some debris of some sort.
Yep. I’m trying to remember how it works, but inside there is a Detent pin that presses against the rooster comb to keep it from going in gear while park is selected if that cable is off or worst yet, that spring retainer on the end of cable stretched during install, which happens a lot, it may not be fully coming out of park
