I saved a stainless bar from a windshield wiper, bent a hook in it and it managed to pop out a stone jammed in beside plug. Ford 5.4, cyl 4.So, I mentioned I need to do 100K service on the wifemobile. 09Journey. Back plugs will be a job. Figured pull fronts and see how they look. Should be easy right. 2/3yes. This one major problem. Something in next to it. Original plugs. As far as I know, never looked at since it left the factory. Only thing I can think is a valve keeper. Tried pokin around with a scre driver and it seems to be wedged…
Failing that,cut a notch in socket and turn plug a little, should be able to blow it out.
