Now this is in my head
Kate Pierson. yummy
We haven't seen any of kay at all but the ground here hasn't dried out in over a month.Kay stopped by at 03:00 in her tropical depression. She cried for about 15 minutes and left, the ground is already dried out so she wasn't that depressed
Kate Pierson. yummy
lol Mornin.She drove a Plymouth Satellite A-faster than the speed of light.
Oh wait... different song
Morning Rob
Yup, factory….should put it back after plug change.
Oh, i found a valve cover bolt wedged in an intake valve on a dodge intrepid with a 3.5. Developed a misfire in first 400 miles.
Did you put it back?Oh, i found a valve cover bolt wedged in an intake valve on a dodge intrepid with a 3.5. Developed a misfire in first 400 miles.
It was really wedged. Tried the wiper metal and it bent hook back. Ended up pealing the rubber grip off a long right-angle pick. Grabbed that with vice grips and pried up on that. Still took a bit of oomph to dislodge it.Yup, factory….should put it back after plug change.
Perpetual energy. Right?
5 grocery stores to find a certain new coffee creamer flavor for my wife… why do it? I don’t know
Moist. I like moist. LMAO I knew a girl that had a moist spot.So here is the bowl I scooped out, went down to shelf rock at bottom. Need bigger toys if I want to go deeper! (Que Karl) you can see the seep in the middle. I am contemplating how to harness that for something productive. And of course a pix of my fearless companion on back side of the pistol bay, chasing a bunny she will never catch!
Ewwww !Are you saying she never shaved her arm pits?
Dig a hole and you will find a stream. It is not just coming out moist. There is a stream in there someplace and it may be and probably is a trickle. Moist trickle Karl. Take a 4" piece of plastic pipe and push it in around the trickle and trap it. Put clay or a bag of cement and seal it and it will come out the end of the pipe and then do with it as you want.So here is the bowl I scooped out, went down to shelf rock at bottom. Need bigger toys if I want to go deeper! (Que Karl) you can see the seep in the middle. I am contemplating how to harness that for something productive. And of course a pix of my fearless companion on back side of the pistol bay, chasing a bunny she will never catch!
