Well, he's in the ER now. He got back to me. Problems breathing again. We need prayers in high gear.
Thanks for the update Rusty.Well, he's in the ER now. He got back to me. Problems breathing again. We need prayers in high gear.
Well, im stressed, max. Simone is slowly getting better. SLOWLY!!!!
Sho nuff.Thanks for the update Rusty.
She is still in our prayers!Well, im stressed, max. Simone is slowly getting better. SLOWLY!!!!
Snow
On my daily prayer list, I catch myself praying 4 to 5 times a day..Well, im stressed, max. Simone is slowly getting better. SLOWLY!!!!
That’s good news! The getting better part, not the stressed part.Well, im stressed, max. Simone is slowly getting better. SLOWLY!!!!
Flurries. Nothing sticking. Up north has measureable on the ground, NWI to upper MIReally?
A truck trans is my guess......Or early Van....By the way Chris... still at a loss in ID-ing this 904.
12 " tailshaft on my original
18" tailshaft on the rebuilt
Everything else measures the same
@slantsixdan might know. He is all about /6 designs.By the way Chris... still at a loss in ID-ing this 904.
Except the placement of the speedo....Everything else measures the same
What numbers are stamped on the side of the transmission body's pan rail?
Well, there's yer problem. That 3rd figure isn't a five, it's a six. 2466 119 is an A904G for a 1965 A-body with 225 engine.2465119W ...
The old trans 2466091 is 1964 A-body 6-cylinder (there are differences between '64 and '65 valve bodies to provide for '65 lever versus '64 button shifters; make sure you're not about to get crossed up by that).
The 2466119 was originally built with a 12¾" extension shaft and housing. So was the 2466091.
The '65 A904s built with the 18" extension shaft and housing were used in B- and C-bodies with 225 or 273 engine.
Either someone mix-matched parts when they put together that rebuilt transmission—the long and short extension shaft + housing interchange together—or this is actually a 2466118 (B/C-body with long extension) that was mis-stamped at the factory.
Hay.....what are you doin in here? LOLThe old trans 2466091 is 1964 A-body 6-cylinder (there are differences between '64 and '65 valve bodies to provide for '65 lever versus '64 button shifters; make sure you're not about to get crossed up by that).
You're right! »vanishes«Hay.....what are you doin in here? LOL
