Stop in for a cup of coffee
Found this annual rain chart yesterday. Ya see that real dark maroonish spot there at the lower right? Go up from there to the next spot the same color, that's right about where I was raised in Barstow. Less than 1" of rain for 2022.
Another day, another way :thumbsup:
Good morning, sons sent me an update this morning
Found this annual yain chart yesterday. Ya see that real dark maroonish spot there at the lower right? Go up from there to the next spot the same color, that's right about where I was raised in Barstow. Less than 1" of rain for 2022.
Wow, the air has got to be dry there, plus the wells..
Like I said, the Mojave is a funny place. A good share of that part of the state all drains to the same point. Mountains to the west more mountains, Nevada side, tail end of the Sierra Nevadas is at the north end and no escape to the sea. There's a spot on the road to Vegas that actually has surface water most of the year, hardly bigger than an agricultural reservoir. The surrounding territory is essentially a massive dry lake.
Do you have the manual? Silly question... it's probably not considered operator level maintenance
Nope. I had a contractor install it. I’ve got the heater elements changed out. Drain valve is clogged so that was a mess and a half. Probably just gonna have the whole damn thing replaced.
I had one that had swirl clean technology. It was supposed to cut down on sediment build up.
Thanks. I have a water softener but I’m wondering if an in-line filter between the softener and the water heater would help any
Well even if I could find the damn anode, menards nor lowes has one in stock. Gonna have to order it :BangHead:
Chris just pull the dam thing out and check it. Not just a universal thing............................
Wow, never realized
If I can. I’ve popped both those tabs, dug out all the insulation, no nut or plug to remove .
Morning fellers, and Happy New Year. In bed at 10, slept through any noise from town. Fed the horses and the dogs and I went for a walk not fun in deep snow.
