I got the snow moved next to my truck. I just heard a avalanche and it is full again.
Sounds like my luck.I got the snow moved next to my truck. I just heard a avalanche and it is full again.
Rough guess early 1920s. That design was used on a lot of issues over several years. I can try to ID exactly which stamp it is after work. Is it a postcard?@zkx14
Can you approximate when this was mailed by the stamp and the postal address?
Looks OK from here Mike just leave it and have a drink and wait for it to melt.
It's a small envelope with another envelope inside containing two 'nickers' for cutting across the grain for dados.Rough guess early 1920s. That design was used on a lot of issues over several years. I can try to ID exactly which stamp it is after work. Is it a postcard?
Wait, you have welding gloves?You know you're doing some serious welding when your welding gloves get so hot you have to throw them on the ground to cool off and put on others to continue the project "Let Alex weld it. He can weld anything." In my dreams.
Or the bucket of water next to you that you drop stinger in periodically to cool it down enough so that the handle does not burn you thru the gloves, when running heavy cover passes.You know you're doing some serious welding when your welding gloves get so hot you have to throw them on the ground to cool off and put on others to continue the project "Let Alex weld it. He can weld anything." In my dreams.
That too After undoing the quick connect in the on the stinger wire Sometimes it just got tossed in a nearby puddle on the ground.Or the bucket of water next to you that you drop stinger in periodically to cool it down enough so that the handle does not burn you thru the gloves, when running heavy cover passes.
On second/closer look… by the size of print, it was printed by a flat plate. The perf looks like 10 all around. That makes it a Scott#462. First issued 1916.It's a small envelope with another envelope inside containing two 'nickers' for cutting across the grain for dados.
I was looking at the lack of zip code implementation.. so between 43 and 63View attachment 1716037128
Stanley also called them 'spurs'.
On the Combination plane there is one on the main section, and another on the sliding section which is easier to see.
In 1918 they got small teeth to create a rack rather than rely on friction to keep them from retracting. But of course back then they continued to offer replacement parts for the older models....
There are some very educated and smart fellows on the thread....you included...Love this thread stretching my understanding
5 digit Zip Codes - Mr Zip! are 1963.I was looking at the lack of zip code implementation.. so between 43 and 63
How heavy is the snow?Not much melting going on. More snow tomorrow and Sunday and not above freezing till next Friday or Saturday.
Prolly a good idea if doing a lot
