dukeboy440
Unless the contacts are mounted horizontally on the same plane, that would put them both with the oil…We walked through it with Hoppy a while back. Risk is that if the coil is side mounted the contact on the upper side may be out of the oil/ fluid. But then there were comments about OEM side mounts. I went epoxy to avoid the chance
