Don't worry about that.How do I get the coolant out of the cylinders? I've wiped with paper but there's some between the piston and cylinder wall.
Minuscule amounts for sure but still ...
I know you're right, Mike. Thanks.Anders - that girl is gonna smoke when you start it - but seriously, an once of prevention is worth a pound of cure.. just drain it and check the oil.. from the sound of it it is probably fine.. but be sure
indeed - you can't be careful enough around an open engine..I know you're right, Mike. Thanks.
It's probably a good idea to put it back together right away or I'll start dropping things into the camshaft ...
it is required now as far as I know. think it started last year. This was the first time they actually looked at mine.No id required here which I think is BS, first state I have been in that did not require it and they are fighting it in the state supreme court for years. It is a unnecessary inconvenience to people
Still not required the dems squashed that one it is still being pushed though.it is required now as far as I know. think it started last year. This was the first time they actually looked at mine.
Use a shop vac and you can suck most if not all of it out. Don't let it sit long because it already has started to rust.Thanks for the input guys! See you all later. I'm going to lift the top an that old radio I bought.
That's crazy! Or wait, is that just the nominations? For the actual election you need to identify yourself, right?This is the only non id required state I have lived in we were actually shocked it was not required even to register.
I'm not sure what you mean, the radio or the engine?Use a shop vac and you can suck most if not all of it out. Don't let it sit long because it already has started to rust.
Same process for both. not sure what they are supposed to do, but...when I go to vote, they have a book of registered voters. I tell them who I am. they find me in the book. I sign. they just look if signature matches my registration signature in the book. as I said, they started asking for ID recently. but, it appears I don't legally have to show it...That's crazy! Or wait, is that just the nominations? For the actual election you need to identify yourself, right?
you are not lying. The sickest I have ever been.oh snap - that sucks!!
