you figure out your cable issues?Do a LCA sleeve to take your mind off it
Going to extend the adjusting rod thread to accommodate the short cable.you figure out your cable issues?
ahh good enough i assume a barrel nut and a bolt with the head cut off? gonna weld it or or just jam nut it?Going to extend the adjusting rod thread to accommodate the short cable.
I'll do the barrel with two cinch nuts. Cut back the existing rod section so I can get some adjustment range.ahh good enough i assume a barrel nut and a bolt with the head cut off? gonna weld it or or just jam nut it?
ahhh yeah.. i was wondering how you would deal with that...I'll do the barrel with two cinch nuts. Cut back the existing rod section so I can get some adjustment range.A
I only need enough of the original threaded section to accommodate the barrel.ahhh yeah.. i was wondering how you would deal with that...
I'll hit the real real hardware store near me and see what options they have Not sure what the thread is on itOr use a turnbuckle Keeping the left hand thread active
I'm getting replacement defrost vents and hoses installed and the new gauge cluster installed. Waiting on the gauge faces to arrive.My goal for the weekend is to get my rear end back together and maybe exhaust on..
did you go with the white?I'm getting replacement defrost vents and hoses installed and the new gauge cluster installed. Waiting on the gauge faces to arrive.
I'll see what the options are. I'll have plenty to work with I think.You can even cut the barrel and weld it back up to shorten it. I am doing this currently to fix my 3pt hitch on my tractor
Went crazy with red. I think it'll be a nice contrast with the chrome. Green led lightingdid you go with the white?
LOL take the bolts outI'll see what the options are. I'll have plenty to work with I think.
Gotta figure out how to get the gooseneck hitch out of the bed.
Lol. It's through the bed. Can't tell if the ball is tack welded to the threaded bolt underneath.LOL take the bolts out
