Stop in for a cup of coffee
With that transmission, I assume your thinking low pump pressure?
Does that also have a rear pump? and does that given driven by the tailshaft only?
Throttle 'kickdown' Shift linkage ?
That and the governer determine how the valves move.
Lemme look in a 66 book.
Thanks Mat.
Don't burn cycles looking. Little shop of Mopar horrors is gonna be closed for a while. Appreciate it though
Thanks Mat.
Well if it makes you feel any better, at least you didn’t catch it on fire and total it like I did.
We’re here to help whenever you’re ready to tackle it again. If you still don’t have it in a few weeks, I’ll drive over and help you figure it out.
Hey guys. Freaking neighbor cat got in our 5th wheel today. Door open loafing it. Clawed the **** out of one of our chairs. Boy I'm pissed
This
I’m assuming the cat is now at some restaurant getting turned into fried kitty?
Good morning guys... i worked on my car yesterday and found i'm missing a spring that goes behind the door panel, it slips over the post for the window crank to keep the panel/handle from rattling... was curious if anyone would know the part # so i can try to find one.. Not sure if A-bodies even have that part though
Ya, I think most A bodies dont use a spring. I'm sure you can find a replacement, maybe at the hardware store. Maybe cut down a radiator hose spring.....
not a bad idea actually, thanks :) But that will drop my car from 48points at carlisle to 45 :(
Have a part number?
Parts Manuals – MyMopar
A bunch or Moanings here this morning must be a Monday!!
GOOD Morning!!
