Chris, if you all work something out somehow and need parts brought, I am heading to NC and then GA in early/mid June. Could bring something...
Thanks Eric.... I'm going to do a bit of research and decide on a course. @toolmanmike and those new heads seems like a much faster way to get me back on the road.Chris, if you all work something out somehow and need parts brought, I am heading to NC and then GA in early/mid June. Could bring something...
8 hour drive if you just wanna come get a pair of heads... could have them this weekend.
They are great, other than the fact that 1/4 of it stays in the tube when its “empty”. I popped the top off and was disappointed to see how much goes unused.Yes they are a god send!
Colonial park roadWhere is that?
Good Morning
Nice to know. You another Chris? LOL my imogies dont work. So have a return finally, guy says it is stuck in advance. OK talk for a while good guy I back my crap up. He had it dynoded at 550 hp. (worked 440) talked to the engine builder thst was with a MSD. Well low and behold mine made 610! They crashed it somehow on install and bent the upper shaft shaft and the advance stuck. Then he tells me it should be mech only. Took care of it, rep means a bunch to me like my word. Holy crap the builder put ten orders to me! Funny how that works egh?So I then see these on FB for $800...(includes factory 4bb intake and Carter carb I don't need)
"Heads, Springs, Keepers, Retainers, Valve Job - All New
Heads have adjustable rockers that are very nice and pushrods for a hydraulic cam. Intake is a 1965 HIPO."
Those shaft shafts are so fragile 610? Not bad there Hoppy 60 horse difference, musta been bent in the right directionNice to know. You another Chris? LOL my imogies dont work. So have a return finally, guy says it is stuck in advance. OK talk for a while good guy I back my crap up. He had it dynoded at 550 hp. (worked 440) talked to the engine builder thst was with a MSD. Well low and behold mine made 610! They crashed it somehow on install and bent the upper shaft shaft and the advance stuck. Then he tells me it should be mech only. Took care of it, rep means a bunch to me like my word. Holy crap the builder put ten orders to me! Funny how that works egh?
Hey, us Chrises are the bestNice to know. You another Chris? LOL my imogies dont work. So have a return finally, guy says it is stuck in advance. OK talk for a while good guy I back my crap up. He had it dynoded at 550 hp. (worked 440) talked to the engine builder thst was with a MSD. Well low and behold mine made 610! They crashed it somehow on install and bent the upper shaft shaft and the advance stuck. Then he tells me it should be mech only. Took care of it, rep means a bunch to me like my word. Holy crap the builder put ten orders to me! Funny how that works egh?
That's not good, what shocks are they?I got a new set of shocks last year , noticed the ride was not very good , took the shocks off and right one just collapses and won't return. Can't be a good sign?
Monroe-Matic plusThat's not good, what shocks are they?
Monroe is generally a good product. They should warranty that shock...Ohhhh, I just put 2 new Monroe Struts on the front of my 08 Caddy DTS today.....Just finished , now to test ride.....LOL.....Monroe-Matic plus
Will give it a try .Do they have a warranty, get you get it replaced?
Same on my Polara only it was the right frontMonroe-Matic plus
Offer em 550 and put the intake/carb back on FB for a couple hundred...
Get yours replaced?Same on my Polara only it was the right front
You can for sure rin adjustable rockers on a hyd cam. They are made for solid. Works with eitherHe came down to $450 including the adjustable rockers and pushrods...but the rods are for a hydraulic cam and I'm pretty sure the 65 is a solid cam (??)
They have them available through Rockauto but I haven't looked. I just found them but they are out of stock now. (they need rebuildable cores I bet)Thanks Eric.... I'm going to do a bit of research and decide on a course. @toolmanmike and those new heads seems like a much faster way to get me back on the road.
Another company with 50/50 junk. Have seen a few monroe products fail lately. Check on warranty, some is lifetime.Monroe-Matic plus
Thanks . Got them from Carquest.Another company with 50/50 junk. Have seen a few monroe products fail lately. Check on warranty, some is lifetime.
