Going to be in the 80's today perfect for TT!
Going to spray weed killer today. I have one of the backpack sprayers but got smart last year and got one for the ATV. I use that for all the ditches up and down the driveway and the ATV trails.
Headed back to NJ tomorrow for the weekend and I will see what other treasures I find in my FIL”s garage.
I should pull the distributor out of the Swinger as well. I have a "too light" advance spring in there and it pings pretty easy. I plugged the vac advance which helped.Let's see, flip of the coin. Do I service the Swinger or the 66 today? The 66 gets a couple sets of fresh points (thanks Hoppy) and adjust the valves as well as a LOF.
I'm not sure about the guru part... Your Credit 41 is a glyphosate (like RoundUp). Different brands have different surfactants loaded in them, makes it stick to the leaves better. That's why some seem to work better than others. It is non-selective so it will kill most anything that has not developed resistance.@Ben Drinkin is the guru on this stuff, what he did.
I need to study up. Round up doesn't have carry over correct? How long before you can reseed?I'm not sure about the guru part... Your Credit 41 is a glyphosate (like RoundUp). Different brands have different surfactants loaded in them, makes it stick to the leaves better. That's why some seem to work better than others. It is non-selective so it will kill most anything that has not developed resistance.
Mike's 2,4-D shouldn't kill most grasses, stunt it a little. Stuff kills most broadleaf plants. Once the grass comes out of dormancy I use the 2,4-D to spot spray as needed.
Crabgrass is a whole different animal. Need to kill it with RoundUp early in the spring and get some pre-emergent down. My preference is a product called Prowl H2O. It is some nasty yellow stuff. Mix in some blue spray dye and 'paint' your lawn green in the spring. Seems to keep my lawn fairly weed free.
No worries, didn’t expect you tooSorry Chris and no don't remember the story.
Just get a goat. Works betterI'm not sure about the guru part... Your Credit 41 is a glyphosate (like RoundUp). Different brands have different surfactants loaded in them, makes it stick to the leaves better. That's why some seem to work better than others. It is non-selective so it will kill most anything that has not developed resistance.
Eat the weeds and fertilize at the same time.Just get a goat. Works better
Which are you bringing to MITP? I would do that one first. Then you are set for the trip.Let's see, flip of the coin. Do I service the Swinger or the 66 today? The 66 gets a couple sets of fresh points (thanks Hoppy) and adjust the valves as well as a LOF.
Good idea there. I am thinking about the 66. I wonder what Keith will bring this year? @66340SEDAN ?Which are you bringing to MITP? I would do that one first. Then you are set for the trip.
Are you bringing Lacey?Which are you bringing to MITP? I would do that one first. Then you are set for the trip.
I chatted with Keith last night. He didn't mention which but likely will trailer the car for the extra shopping roomGood idea there. I am thinking about the 66. I wonder what Keith will bring this year? @66340SEDAN ?
It is the plan, depending on the weather. If a bad day, then likely will trailer, bad weather weekend, then wont bring it at all. The Charger isn't ready, hopefully next year, so it is the only option.Are you bringing Lacey?
Always the weekend after Memorial Day. We will be there June 1-4When’s MITP again?
Glyphosate becomes essentially inert in the dirt. I'd still give it few weeks before reseeding.I need to study up. Round up doesn't have carry over correct? How long before you can reseed?
Thanks Rick.Glyphosate becomes essentially inert in the dirt. I'd still give it few weeks before reseeding.
Can't reseed behind the pre-emergent tho. It prevents seed from germinating.
Mopars in the Park right?Always the weekend after Memorial Day. We will be there June 1-4
Yes, Stillwater MNMopars in the Park right?
