zkx14
Duster De-ruster
We have that all over behind work. Looks like cat turds. Lol. Wouldn't want to step on it, especially not when fresh This pic was last week.Goose **** is slicker.
Good Morning
Those look tasty!
Me to, but My dancing skills are failingHonestly I can still get off the ground without holding on to anything but getting harder.
All the sudden I could smell oats or feed, helps hearing about things I use to do for enjoyment and pleasure.Morning fellow old farts, spent the day shopping, cleaning, and doing laundry, good times. Horses are fed and the dogs and I went for our walk. Coffee is hot.
Love cardboard, I slide so good on it, like it over a creeperEven on cardboard.
Tiger got out of the tank and now resting, looks tired
I can still do the shuffle. lolMe to, but My dancing skills are failing
I don't want to be a Debbie Downer but I hope the brake drum lathe can chuck up the hubs with no bearings. You may want to ask them before you leave your shop.I did it, removed all the inner and outer wheel bearings and races in the front I cleaned everything up and now I need to take the drums to get cut. after I get that done, I will install the new bearings and seals.
I really enjoy working on this car. I am learning A LOT! Thanks to all of you!!
Man bummer, I didn't know that? I guess I can throw the old stuff in just to get it done.I don't want to be a Debbie Downer but I hope the brake drum lathe can chuck up the hubs with no bearings. You may want to ask them before you leave your shop.
LOLFront? Just drive he races out they are made to do that. Clean out the grease you will see where the punch fits. Use brass tapping them back in. Super easy. If he is checking the drums on a brake lathe have him do it with the new races in that way it will be "true" to the new bearing. I know your OCD!!!!!!!
oh, ok missed that part
Just be sure that the new races are all the way home in their seats. Otherwise the drums will not turn trueoh, ok missed that part
Bearing races are usually in to machine drums.I did it, removed all the inner and outer wheel bearings and races in the front I cleaned everything up and now I need to take the drums to get cut. After I get that done, I will install the new bearings and seals.
They need to have races in,the cones use them to centre in the boreJust called all the stuff needs to be out for them to turn them....................Lucked out on that I guess.
