Show, swap? Nice to go to an all Mopar show, been to a couple where there were only a few out of hundreds.Good morning, tired after 3 day Mopar show
If its 5 grand we do, but below that, no sales taxesIn PA you do pay sales tax when you buy one.
Mercury too, yep those long quarters and beuityful bodies, 66 and 65 knew what we as pony cars wanted, love them as well as the nova in those yearsLove Comets... would like to have one someday...
I don't see 300 bucks worth, seen these behind glass for 25 dollars here in Arkansas
Be careful out there
If you want thicker for overkill could pack it with grease like the @dukeboy_318 mentioned for the old powerwagons.I am sure it is overkill but why not. The majority of driving will be in the summer, so heat should not be a problem and when I am running it on the track
Yep agreed.If you want thicker for overkill could pack it with grease like the @dukeboy_318 mentioned for the old powerwagons.
No?
That's my point.
Thicker is not better.
Better is the viscosity range that it splashes and sticks to the gears and maintains film strength and shear resistance while getting squeezed between the gears.
I do not know the heat generated in diffs while drag racing, but generally figure the factory selected grades after considerable testing.
Lets see if Direct Connection recommneded different.
Yep agreed.
Gale Banks has a great video showing this. They made stock diff covers and molds of popular aftermarket ones out of clear acrylic and stuck heat sensors in and put them on a dyno with a camera and a thermal camera showing how the various covers did with the various oils and such.
The conclusion was rather shocking. For example, the cover that kept the diff the coolest and had the best flow. The factory. And this was a consistent across various axle types. The Dana 60, the gym 14 bolt, the Dana 80 etc. Even over his own diff cover.
The conclusion was that unless one was running a pump, all the aftermarket covers that had capacity, the cooler oils stayed at the back of the cover and the rest basically whiplashed and aerated instead of cooling.
I’ll see if I can find the video but it definitely was cool
no.. if it was 1 of 1 and polished to a show quality then it would be a FBBO thingIts a FBBO thing, seriously
If you find it, that would be cool.Yep agreed.
[SOLD] - 273 high performance commando engine for sale $1000 obo
This original engine came out of a 1967 rust red Plymouth barracuda fastback. Unfortunately the original car burned in a garage fire with a 340 engine that my father had put in for kicks. It was my dads car and I was hoping to find another rust free body for the 273 but just don’t have the time...www.forabodiesonly.com
Had a few of mine go for pages!
No?
That's my point.
Not seeing anything in a quick scan of the Chassis book. I'd trust somoneone like Dr Diff and anyone running stock eliminator. That's a game where every savings counts.
Yep agreed.
I appreciate the feedback and information……so 75 90 is recommended and what I should be using?If you find it, that would be cool.
Gale banks - an expert before there was youtube!
Here's a gear oil viscosity graph from Richard Widman.
Similar to motor oil, the non W grades are spec'd at 100 C (212*F).
So a 140 is about twice as viscous as a 90 at 212 F.
What is most interesting is the viscosity below 212 F, especially the multi-grades.
Keep in mind 90 is the thickest grade Chrysler spec'd before good multi-weights were on the market.
From here
[/URL]
He also has a white paper on the differences in GL4 vs GL5
[/URL]
90 was the factory for over 10*F, so 75W-90 would probably be the best modern equivalent.I appreciate the feedback and information……so 75 90 is recommended and what I should be using?
Yeah email Cass at dr diff. Cass is THE subject matter expert. No offense to Matt as mat is very knowledgeable as well. But Cass has been dealing with these things on a daily basis and that’s why he’s Dr Diff. Outside of this forum , he’s one of the very few I’d trust in anything Mopar90 was the factory for over 10*F, so 75W-90 would probably be the best modern equivalent.
Might see what Dr Diff or some others have to say but the 140 seems really high viscosity in comparison.
As a tribute car it has to do street and strip, and I assume your not tearing down after every event or two. That's one aspect about engine racing oils people seem to ignore when they use them on the street.
